Old 08-27-2014, 03:24 PM   #11
Rich46's Avatar
Send a message via Yahoo to Rich46
Thank you ! I got to look closer only have 3 plugins inside, this was by the fuse box, have to lay on the floor
to see it.
Rich46 is offline   Reply With Quote
Old 08-27-2014, 03:25 PM   #12
Kaadk's Avatar
NP. Glad it worked out.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 10-22-2014, 08:19 AM   #13
Originally Posted by Pooneil View Post
This is the fuse rating and wiring use on my camper.
1. 10 Amp Water Pump
2. 10 Amp Air-conditioner shuts off
3. 15 Amp Propane detector, Water heater, Furnace
4. 10 Amp Inside lights Interestingly my LEDs still glowed a little?
5. 20 Amp Fridge
6. 30 Amp Main battery With this pulled and the camper unplugged, nothing worked inside. This was the only fuse that shut off the stereo and the nightlight. With the camper plugged in, there was no effect.
7 40 Amp is marked as reverse battery polarity protection.
I opened the service side bench yesterday and found an addition to the list. The furnace has a 7.5 amp inline fuse that is only accessible after unscrewing the bench cover. So it is off to the store today to get a new fuse to put in my parts box.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 12-03-2014, 06:01 PM   #14
RedLdr1's Avatar
Here are a couple more additions to the list:
The T19 and T21 Series trailers with the Power Lift Roof have an inline 7.5 Amp ATO fuse in the CoolCat / Water Filter compartment under the bed. It can be a bit hard to spot in the hoses for the water filter and CoolCat "stuff" but it is in their!
I ordered our T21 with the OEM Power Front Jack and it has a inline 7.5 Amp ATO fuse in the battery box.
We also have the 7.5 Amp fuse for the furnace as Pooneil listed in the previous post.
I'll list any other fuses I find as I explore the trailer more....
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is online now   Reply With Quote
Old 05-14-2015, 10:03 AM   #15
RedLdr1's Avatar
A quick update to Tom's (Pooneil) list with the addition's I've found. This will keep all the info in one post.
Note: Not all models, or trailers, will have all the Optional fuses.
5. 20 Amp Fridge
7. 40 Amp is marked as reverse battery polarity protection.
8. 7.5 Amp Furnace (Optional) Inline fuse located near furnace.
9. 7.5 Amp Power Lift Roof (Optional, currently High Wall models only) Inline fuse located in CoolCat compartment. Just follow the wires from the lift mount on the outside wall.
10. 7.5 Amp Power Front Jack (OEM Option) Inline fuse located in Battery Box.
Wayne
Old 07-25-2016, 05:52 PM   #16
I just replaced the WFCO 8735 converter with a Progressive Dynamics PD 4135 because the WFCO would never go into trickle mode, and would boil the battery water away if I left the camper plugged in long enough.
I had to move the wiring from one converter to the other one circuit at a time. I observed some differences from below with the WFCO wiring. My differences are in red.
2. 10 Amp Air-conditioner shuts off. Actually powers the electronic thermostat and perhaps some relays. The Cool Cat will not work without this 12V circuit.
3. 15 Amp Propane detector, Water heater, Furnace, stereo, porch light, tongue light, night light. Basically, all other fuses were single circuit. This is the only fuse with multiple circuits.
4. 10 Amp Inside lights Interestingly my LEDs still glowed a little? Powers everything above the fold line. This includes the Fantastic Fan and the 2 interior lights. Power goes through the plunge switch at the left forward corner to shut this circuit off when camper is folded down. Fantastic Fan has a separate fuse at the fan (3 amp?).
5. 20 Amp Fridge Fridge manual says fridge uses 13.25 amps on DC.
6. 30 Amp Main battery With this pulled and the camper unplugged, nothing worked inside. This was the only fuse that shut off the stereo and the nightlight. With the camper plugged in, there was no effect. On my 2014 A122, this went to the battery only (WFCO converter), and did not power anything else. The PD converter does have this circuit, the battery is fed directly from the 40 amp reverse polarity protection fuse.
7. 40 Amp is marked as reverse battery polarity protection. On the WFCO, there is no external wire coming to this fuse.
What else I learned in the re-wiring:
- I installed a bus bar to join all the negative wires instead of the series of wire nuts.
- I installed a small bus bar for the positive wires on Fuse #4 above.
- all the wires and connections to the WFCO converter were labeled and were the correct minimum wire size for the fuse/circuit breaker installed. Do not use bigger fuses on any of the circuits - the wiring is not sized for more current.
- All AC outlets are located on the same 120V AC fridge circuit - and have a 15A circuit breaker. The GFCI controller outlet (with the test/reset buttons) is located right beside the converter (under the dinette left seat in the A122).
Fred W
2014 Rockwood A122 A-frame
Old 08-29-2016, 12:29 PM   #17
Randy Hoffman's Avatar
Just brought our A122BH home and set it up. Nothing would work off the battery, so in checking the 30 amp fuse I found the left fuse terminal was not making contact with the fuse prong. I tightened it a little with small needle nosed pliers and all is well!
Randy Hoffman is online now   Reply With Quote
cat, fuse
