Old 08-11-2013, 06:42 PM   #1
handbuilder's Avatar
Fuse Identification?
This has been covered under a previous A Frame thread but I cant find it, hoping someone can direct me to that thread? I meant to mark my fuses at the time & didnt...grrr.. maybe the member who shared his fuse findings (ie: Fuse 1 operate xx, Fuse 2 operates xx etc) will post again? Please? LOL All I remember is that it was within another thread and maybe last summer or Fall?
My apologies for repeating a thread already discussed but where is it? haha
A Sincere "Thanks" in advance!!
Tamara
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-11-2013, 07:50 PM   #2
This is the fuse rating and wiring use on my camper.
1. 10 Amp Water Pump
2. 10 Amp Air-conditioner shuts off
3. 15 Amp Propane detector, Water heater, Furnace
4. 10 Amp Inside lights Interestingly my LEDs still glowed a little?
5. 20 Amp Fridge
6. 30 Amp Main battery With this pulled and the camper unplugged, nothing worked inside. This was the only fuse that shut off the stereo and the nightlight. With the camper plugged in, there was no effect.
7 40 Amp is marked as reverse battery polarity protection.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-11-2013, 07:57 PM   #3
Tom!
Thank you!
Thats exactly what I was looking for!!
Old 08-11-2013, 08:02 PM   #4
Originally Posted by handbuilder View Post
Tom!
Thank you!
Your welcome.
Tom
2012 Rockwood A122S
Old 08-12-2013, 09:24 PM   #5
Thanks! I too wondered how to label the fuses so I know what to look for the next time something doesn't have power. My electrical failure turned out to be a tripped GCFI outlet! Found out that not only the outlets lose power but also the refrigerator when hooked up to shore power! Another great learning opportunity!
Cyndi, Stu the Wonder Dog & Mandi the 10# Guard Dog!
2012 6 cyl. Toyota Tacoma Double Cab
2013 Flagstaff T12RB A-frame
Cyndilee is offline   Reply With Quote
Old 08-13-2013, 08:44 AM   #6
As you found out Cindi, every plug on a camper will be "downstream" of a GFCI.
Tom
2012 Rockwood A122S
Old 08-27-2014, 02:04 PM   #7
Rich46's Avatar
Send a message via Yahoo to Rich46
I realize this is an older thread, but here goes my 2012 T12DDST when hooked up to 30 amp plug
Worked fine, had to move & hooked up to heavy duty 110, the heat pump, 12vt system & lights work.
None of the plugins work. Oh the clock on micro wave works, just have not turned it on. All the breakers
I've tripped & reset, just no power to plugins. Note: when parked I had a solar charger on the battery.
Is this a safety feature, or something else. Trying to get set up for storms in gulf in case i need to leave.
Rich46 is offline   Reply With Quote
Old 08-27-2014, 02:09 PM   #8
Kaadk's Avatar
If your outlets are dead, but everything else works then it's probably your GFI. Try resetting it.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 08-27-2014, 02:15 PM   #9
Rich46's Avatar
Ok where is this?
Old 08-27-2014, 02:17 PM   #10
Kaadk's Avatar
I don't know for your model. But it's one of the outlets somewhere. (Might be in a storage compartment too.)
Hopefully somebody with an A-Frame can point you in a better location.
cat, fuse
