09-26-2012, 04:16 PM
Fuse Panel on A122
I haven't seen anything yet on this, so here goes.
Does anyone know what the 6 fuses are on the DC panel in the A122? The 120v panel is marked, but not the DC. Fuse #6, a 20amp, keeps blowing.
Gary & Linda S
Crowsnest Pass, Alberta
2020 RPod 195
Dodge Durango 3.6l AWD
09-26-2012, 05:40 PM
Gary my first question is what's not working ?
20 amp is fairly large for most it's in a camper.
Is the converter charging ?
In my 5er there all 15 amp and I have slide outs.
Does it blow as soon as you stick it in ?
12v items include
Water pump
Fridge
Lights
Hw heater on gas
Water pump
Awning
Power jacks
Slides
You don't have some of those items
So let's narrow it down to what's not working
Turbs
09-26-2012, 06:36 PM
Hi. I think it's the fridge, but it doesn't appear to be working on 110 either. Pump, lights and furnace work. That leaves fridge and ?? (sterio) No awning, power jacks, slides. There is also a red light on constantly with or without a fuse. I had a light bulb moment, with a little help, and pulled individual fuses to see what went off. Found the three. Now I need to get a couple more fuses to test everything else.
Gary & Linda S
2020 RPod 195
09-27-2012, 10:58 AM
Check and make sure that more than one of the Frig opions is not on. Having both the 110VAC and 12VDC on at the time could blow the fuse.
09-27-2012, 11:53 AM
Thank. Only one of the switches is on. I might have had them both on at one time, but that was only after the issues. Think I have the fuses figured out. #6, sterio I think still has the red light. Will work on that.
Thanks folks for the help. That's what this forum is all about.
Gary & Linda S
2020 RPod 195
09-27-2012, 06:52 PM
Fuzies ...
If anyone has the plans for the 12 volt fuses, top to bottom left to right ... it will certainly be helpfull to the forum ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
09-27-2012, 07:41 PM
d-mo
exactly what I was thinking d mo !
09-27-2012, 10:56 PM
My only response to that is 'good luck'. Since the person that did the assembly on the 12v stuff might have not done it the same for every trailer, each one may be different
So far I have 1. Water pump. 2. ?? 3. Furnace. 4. Lights. 5. ?? 6. Sterio.
AND today hasn't been fun. 6 hours driving and I find that there is no 12V. No cold fridge, not even any lights!! Then I connect the 'city water' for the first time and flood the place. That #$@$ filter thing came loose!! So, not a happy camper. Another glass of wine will help, though. I do, however, have 110.
In Kaslo, BC for what they call the Sufferfest. Volunteering for a run, XC bike and downhill bike weekend. Distances from 2km to 200km 3 day run.
My A122 is so very, very comfortable. This is the camping life folks!!!!!
Gary & Linda S
2020 RPod 195
09-28-2012, 07:48 AM
Flagstaff 22FBS
There may be a blade type fuze behind the outside (upper?) panel for the refrigerator that has blown.
Or
There is a (30 amp) fuze out front by the propane tanks that connects the battery to the whole system. It has blown on us when we were plugged into the "shore" power and then plugged into the tow vehicle at the same time. We unplug shore power before plugging in the TV for travel. With that fuze blown, could be why you had no lights or 'fridge and the battery will not be charging, so no DC power either.
The 20 amp fuze that you labeled as for the " #6. stereo" probably also runs the microwave and an outlet or two. That would be the main reason for it being 20 amp.
That's all I know for now.
Deb
Deb & Gary
2021 Ford F150 Lariat 3.5 EcoBoost, 2021 Flagstaff 22FBS
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
09-28-2012, 09:03 AM
If you are connected to shore power and have the fridge on 12v you will blow fuze's.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
09-28-2012, 10:10 AM
Just checked outside. The 20amp fuse by the propane is fine. Can't find one outside in either of the fridge panels. I will keep trying and let you all know.
Thanks to everyone for helping out this rookie. Rookie with all conveniences, that is. Previous camper was a Kamparoo with no ammenities.
I don't think the microwave runs on 12v. While there are no labels telling what each fuse is for, there are labels indicating what amperage they should be.
Gary & Linda S
2020 RPod 195
09-28-2012, 10:28 AM
Solved. #6 apparently controls, at least, stereo, lights, ceiling fan. This was a fuse that was giving me fits. Replaced it and, so far, all is well.
Thanks for the tip about not having fridge on 12v when connected to 'shore' power. What?? are we sailors?
Again, can't thank you all enough. I am sure I will be back.
Gary & Linda S
2020 RPod 195
09-28-2012, 06:33 PM
ok just turned every thing on and pulled fuse's one at time, as numbered
12 volt
F1 10 amp water pump
F2 10 amp thermostat control
F3 15 amp co/propane detector
F4 10 amp inside lights and ceiling fan
F5 20 amp fridge
F6 20 amp radio
at the bottom is a 40 amp listed as reverse battery protection
red lights by fuse light when fuse is blown and item is on
120 volt
main 30 amp
B1 15 amp 110 outlets
B2 15 amp microwave
B3 20 amp Air Conditioner
hope this helps
2012 A122BH
TV1 2006 Honda Ridgeline
TV2 2014 Chevy 1500 Silverado Crew cab
10-15-2012, 12:44 PM
When you lose DC power is also helpful to check the in-line fuse at the battery, It corrodes over time/moisture- a simple fix.
Anne
10-15-2012, 09:08 PM
There is a learning curve to all this stuff, but coming from no amenities to the A-frame is going to be great fun for you. You can keep your battery charged on household current or other trickle charger when stored. The detectors and converter do use battery even when stored unless you disconnect the battery.Just remember you cannot operate the A/C, heated mattress or microwave on battery or on your household current. They require the 30 amp provided at campgrounds. Be sure you get a plug to convert your 30 amp plug to 50 amp hookups just in case your site only has 50 available.Use only one power source for the frig, propane is most efficient and will run almost forever on one tank- coldest spot is on the bottom/milk will get icy if set to high cold. Battery is least efficient. The furnace will use up your propane if on more than approx 8 hours. Avoid frying food inside to avoid getting greasy film on the inside of the camper eventually. The water pump is only needed when using your stored water/not when connected to campground source. Keep a small supply of various fuses just in case.........have fun! I live in Florida with two Dobermans that love to camp- especially in colder climates!! Anne
06-14-2013, 02:55 PM
Just a few days ago the problem with blowing the inside light fuse was solved. The wires for the lights come up thru the frame (for want of a better word) at the drivers side front corner. The wires connect to a switch that will turn off the lights, if left on, when the top comes down.
One wire was bare and when I put the 110 power on it blew the fuse. I taped it up and it appears to be OK. No idea why there is no rubber grommet in the hole.
Gary & Linda S
2020 RPod 195
07-02-2013, 03:41 PM
What type of fuses do I need to buy for replacements? I have a 2014 rockwood a122bh.
07-02-2013, 03:52 PM
Pretty standard car fuses. Just check the panel to see what you have there. Sometimes A Frames are wired a bit different. My fuses seem to control different things than others.
The one I have been having trouble with is the one that controls lights on 12V.
Gary & Linda S
2020 RPod 195
07-02-2013, 03:53 PM
Ato automotive fuse.
Mostly 15amp
Turbs
07-02-2013, 04:40 PM
Here is the converter fuse panel on my A122S. Your's should be identical
Fuse Panel by b2220128, on Flickr
These are standard automotive blade fuses. Just take one to a parts store and they will fix you up.
10X3
15X1
20X1
30X1
40X1
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
