Old 05-20-2014, 02:40 AM   #1
Jsusluvsyou's Avatar
Gas Alarm
Took a122 bh 2014 out for 1st outing turned water hose on and turned gas water heater on few minutes later gas alarm sounded... Turned gas off used cold water. What did I do wrong? Anyone else has same problem? Was thinking to go to 12 volt water heater anyone else change?
Jsusluvsyou is offline   Reply With Quote
Old 05-20-2014, 02:41 AM   #2
Gas Alarm ...
Old 05-20-2014, 05:57 AM   #3
I have not heard of a (12V) Water heater? My friend had a (12V) Coffee Pot,and he threw it away! Youroo!!
Old 05-20-2014, 06:19 AM   #4
Assistant TP Supervisor
Spiders maybe plugging the burner, check for red flame or black soot something other than a normal blue flame. if the flame has gone out eventually the thermo couple in the water heater with no flame would shut off gas supply. Maybe have a RV tech check out the heater for a malfunction.
B and B is online now   Reply With Quote
Old 05-20-2014, 07:04 AM   #5
TURBS's Avatar
I agree with the above.
It's very very possible there's a spider Web in the burner chamber and needs to be cleaned.
TURBS
"Sabre owners united"
Old 05-20-2014, 07:11 AM   #6
There is no 12V water heating. It would drain your battery in minutes.
Propane leaks are not to be taken lightly. The worst case scenario is an explosion and fire. Something not impossible with the water heater kept within the closed up environment under the bench.
Your narrative suggests to me a malfunction of the water heater. Like other systems, the propane can be self-repaired by a knowledgeable owner. It could be as simple as adjusting the air intake for the burner or clearing insects nesting around the WH.
But, if nothing obvious is present and unless you are quite comfortable that you have tracked this down and fixed it, getting it checked by a pro is a good plan.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-20-2014, 07:25 AM   #7
Mr. Dan's Avatar
... if nothing obvious is present and unless you are quite comfortable that you have tracked this down and fixed it, getting it checked by a pro is a good plan.
I agree with Pooneil.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 7; booked = 22
Old 05-20-2014, 08:19 AM   #8
Will do thanks
Old 05-20-2014, 08:27 AM   #9
wmtire's Avatar
Is your water heater a dual propane/electric model? If so, you can use the electric side, until the propane side can be fixed.............since the propane and electric heating element (if equipped) operate independent of each other.
This way you would still be able to have hot water until the problem with the propane can be figured out.
Do you know if you have the Suburban, Atwood, or other water heater?
If the Suburban, this FAQ below may help you in determining if you have an electric heating element side to it.
Suburban's electric switch and much more
The only drawback is you must be hooked up to a form of 120 volt shore power to use the electric heating element.
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 05-20-2014, 01:54 PM   #10
FR A Frames come with a DSI propane as the stock WH. Any electric would be aftermarket.
Tom
2012 Rockwood A122S
gas
