If you have a hygrometer, check the cells in the old battery. If the specific gravity of the cells is significantly different, it will cause the good cells to boil while trying to bring the weak cells up to charge. Another member just had this issue ( battery tested good on Battery Tester) but cells were imbalanced. New battery and everything is working well I am guessing install of new battery will correct your problem. After about 2 hrs of being plugged in feel battery it feels warm you might have a converter issue.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
