Apologies, I took the picture but failed to post it. (Busy life/work)
Here's the exterior side shots of the section that was reinforced with the aluminum angle. I plan on painting them black right away but this gives a good idea of the mod.
I forgot that the 214HW already has gas shocks on the front. (Wish my 212HW had come with them factory like that!
"The buckling is actually in the front panel between the door and the gas prop for the dormer on the A214HW. I think it imparts the twist through the rear panel and then pulls the front panel towards that side."
Actually, I don't think that any buckling on the front has anything to do with the rear panel. Regarding forces, they are isolated from each other for the most part.
I think what is occurring is that the slight buckling is from the same thing as my own. What happens is that you have a pivot point, (the hinge), and you're pushing against that with the springs 1/4 distance from the hinge.
Then when you close everything up, you're pulling (either with the bands initially or the latch eventually), at the maximum distance which is at the very end. The roof *should* be stiff enough to handle the force applied lower down without any buckling what so ever, but I think the material is just slightly thinner than they should have gone with.
Because of the dormer I don't think a piece of aluminum angle would necessarily work, however you could possibly use a piece of aluminum flat. You could either reinforce the whole front section or just half (like mine). (either way would be fine I think)
That said, as your lifts are factory installed I would touch base with the dealer fist to see if they can/will do anything about it for free.
Regarding your actuator, with those existing gas lifts on the front I don't think it's actually lifting that much.
You could swap out the actuator for dual gas lifts on the rear... but I would be concerned with the ability to pull the rear roof down to close it.
Likewise you could go stronger lifts on the front but be aware that that will increase the force and buckling concerns.
Regarding the pictures I submitted before, the top picture was the flexing on the front with a 60lb gas shock prior to being reinforced and the lower picture was after I added the aluminum.
