Old 08-17-2013, 04:37 PM   #1
GEE, I've got more questions on which one to get?
I am torn between the Toy Hauler, non-storage one, the storage box in front or the one with the small storage rack in front.
I have a 2011 V6 double cab Tacoma 4X4 automatic with tow package.
I like the floor plan with the permanent rear bed.
1. I'd like the toy hauler, but I think my ATV (400 lbs.) would put to much weight on my hitch. Maximum hitch weight is 350 lbs.
2. The one with the fiberglass storage box in front, but can I secure it so I can keep a generator & other stuff without it getting broken into?
3. The one with the small storage rack in front. Is this rack useful enough to store enough stuff in it?
4. I think the one without any outside storage is out of the question.
All advice is appreciated.
Signed "CONFUSED".
gt40 is offline   Reply With Quote
Old 08-17-2013, 06:49 PM   #2
No opinions from anyone?
Old 08-17-2013, 06:56 PM   #3
TURBS's Avatar
I can't give an opinion as I'm not even sure I know of what you speak of without pictures of what units your talking about.
Btw posts get buried quite fast on this forum sometimes and they just get missed.
Turbs
Old 08-17-2013, 07:11 PM   #4
Here is the toy hauler & small front rack & the front storage box:
Name:	TOY HAULER 1 .jpg
ID:	38014   Click image for larger version
Old 08-17-2013, 07:23 PM   #5
TURBS's Avatar
Ok I see.
Here's the issue I'd have with the toy hauler depending on what your towing it with.
A) your going to overload the capacity from your own admission albeit by 50 lbs.
B) hauling a 400 pound four wheeler is also going to increase your hitch weight by that much also.
If your looking at small trailers to begin with I have to assume your tv doesn't have much capacity.
Turbs
Old 08-17-2013, 07:38 PM   #6
Originally Posted by f1100turbo View Post
Ok I see.
Turbs
My Tacoma can pull 6,400 lbs.
ID:	38027   Click image for larger version
Old 08-17-2013, 07:39 PM   #7
TURBS's Avatar
What's the ccc (cargo carrying capacity)?
Found on the tire loading sticker on the door jamb or door.
Old 08-17-2013, 07:42 PM   #8
TURBS's Avatar
Such as.
Old 08-17-2013, 08:10 PM   #9
Please look at post #6 again f1100turbo.
What are your suggestions?
Old 08-17-2013, 08:14 PM   #10
TURBS's Avatar
Ok so you have 1200 lbs to work with.
What's the hitch weight of toy hauler?
From that 1200 lbs you need to deduct...
Passengers, dogs, cats etc etc
Any cargo within truck.
Any and all cargo in the truck bed.
Receiver ball mount.
Tongue weight of trailer no 4 wheeler
Or tongue weight of trailer with four wheeler.
My guess is your going to be way over.
Turbs
Old 08-17-2013, 08:22 PM   #11
TURBS's Avatar
Normally you'll run out of ccc before you even get close to the truck towing weight capacity.
Example.
Using your truck
You may find a trailer that is only 5000 lbs ok super I can tow that!
But if trailer has a 300 lb hitch weight dry that may climb 200 lbs after adding cargo.
In your case 400 lb four wheeler plus a 300 lb hitch weight now your at 700 lbs
Add two passengers at 150 lbs each and your at 1000 lbs
Add coolers to truck bed 150lbs say
Fire wood 100 lbs
actual ball hitch 100 lbs
See where I'm going with this?
Old 08-17-2013, 08:25 PM   #12
Would this help me? I think I won't be able to take ATV with any of these A-Frames even in the back of the pickup.
Name:	air bag .jpg
ID:	38034   Click image for larger version
Old 08-17-2013, 08:31 PM   #13
Jeep4Two's Avatar
Helper springs won't change the ccc of your tow vehicle. Only improve the level and stability.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 08-17-2013, 08:42 PM   #14
Looks like I won't be able to pull one of these A-Frames, but you can with your Jeep. How come? Do I need to trade in my Tacoma and get a Jeep? Yours is only rated for pulling about 2,000 lbs. if I remember correctly. If I add more leaf springs would that help?
I am getting more & more confused. Maybe I'm just hard headed.
Old 08-17-2013, 08:59 PM   #15
Always Learning
Example.
Using your truck
Fire wood 100 lbs
Here's an article I wrote for my inlaws to figure out what their 4Runner could tow. See of it helps describe what Ron is saying:
http://learntorv.blogspot.com/p/what-can-i-tow.html
Basically, you need a better feeling of your weights to decide what you can pull. With your 1,200 pounds of carrying capacity, you do have some flexibility.
I will say, you'll fair way better with a low profile camper than a full-height travel trailer.
Old 08-17-2013, 09:06 PM   #16
1A Camper's Avatar
Or you could balance your trailer. ( put weight in the back of the trailer)
Most experts agree that an acceptable tongue weight for any trailer is somewhere between 9 and 15 percent of the gross trailer weight (GTW).
So if you are towing 6000 lb you need 600lb Tongue Weight. That will now give you 600lb to play with it loading the TV.
1A Camper is offline   Reply With Quote
Old 08-17-2013, 09:09 PM   #17
Retread Popup Owner
Wojo's Avatar
This is all just my personal opinion. I looked very seriously at the model with the large front deck, and almost pulled the trigger on it. I came to the same conclusion regarding tongue weight and loading the quad.
I then came to the conclusion that I didn't want to store everything inside the camper or in our tow vehicle, so I'd likely wind up buying some type of storage bin to secure to the front deck. That decided it for me, because that model is already about 200# and a few bucks more than the model we ended up with...and I'd have been adding more weight and expense by adding a truck type storage box.
I still really like the concept of the front deck. It just didn't turn out to be a good fit for us.
2014 Flagstaff T12DDST A Frame
2015 Nissan Xterra
2015 Nissan Frontier
Camping Photos
Camper Mods
Wojo is offline   Reply With Quote
Old 08-17-2013, 09:16 PM   #18
Jeep4Two's Avatar
I'm not saying I'm in spec. I did a couple things to make me comfortable.
First, my rated tongue weight is 200. However the 4 door (same engine, hitch, and trans) is rated for 350 (3500 towing). Only difference is wheelbase length really.
To overcome the excessive lift of a tongue weight of near 300lbs of my A126 I added a WDH hitch. That gave me good level weight distribution. I also pack minimally.
Additionally I added an aux transmission cooler as an extra precaution as the Jeep auto trans tends to get hot and even if not towing many recommend it.
Ill be honest, I've not done the math on ccc on the Jeep. I just looked at the door tag. My Jeep has a 700 lb ccc. Figuring 400 lbs in human weight, 80 for the hitch weight and 200 lbs of 'gear' I'm still under. However ill be over on tongue and total towing. Trailer is 1994 lbs dry, add battery propane, and 'gear' I'm sure the trailer is close to 2300lbs.
The real issue requires getting loaded and weighing. I've also not done that. The axle weights are important too. Maybe someday ill stop and he weighed to see how I stand.
Your truck is surely ok with the front storage units (open or closed) or the regular non-storage/toy hauler.
Jeep4Two
Old 08-17-2013, 09:25 PM   #19
Ok the hitch weight for the one with the storage rack in the front is 261 pounds.
This means that only 89 pounds can be added to make 350 pounds. I can not find out how much the sway control system weighs. I'm guessing that it might put me over 350 pound weight limit on the tongue hooked up to the ball. This means I might as well save the money by getting one without any kind of storage in front of the A-Frame. Then with only two people I will have to pack the coolers and other stuff in the back of the Tacoma and inside the trailer.
Does this sound like a good plan or could I get the one with the small storage rack if I put enough weight inside the trailer?
Old 08-17-2013, 10:11 PM   #20
Herk7769's Avatar
So to add more fuel to the discussion, you need to understand that a WD hitch does not reduce tongue load; it just "distributes" it from the rear axle to the front and camper axles.
The hitch attachments "see" the entire load.
Tongue load must never exceed the hitch rating.
Name:	How WD hitch Works.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
