08-12-2018, 08:42 AM
#41
Micro-Air EasyStart 364 with 10,500 BTU Dometic Cool Cat wiring diagram:
https://cdn.shopify.com/s/files/1/18...44898753351299
Current TV: 2006 Chevrolet 2500HD Duramax LBZ 4x4
Current RV: 2014 Rockwood A192HW A-Frame
Former RV's: 24' Pioneer travel trailer (w/EQ2 hitch), Northstar truck camper
09-01-2018, 09:55 PM
#42
My Honda EU2200I starts and runs my 10,500 Cool Cat A/C in all conditions using the Micro Air Soft starter. Easy installation. Happy Camper.
09-02-2018, 10:09 AM
#43
What else can you run with that setup. Lights? coffepot? or just the AC?
2017 Coachman Viking 21RD
2018 Chevrolet Colorado with tow package
09-02-2018, 11:30 AM
#44
Lights probably. Coffee pot, NOPE, not while running the a/c.
09-02-2018, 12:02 PM
#45
Per my testing, with a Honda EU2200i and a Micro-Air EasyStart on the AC, I was able to run the AC and the converter at the same time. I purposely discharged my battery to the 50% 12.0V state of charge to put a load on the converter. You could also run the lights and low load DC items like the radio at the same time. Running any additional heavy AC loads like a microwave would probably put the genny into overload.
Funny how I see people saying on forums and facebook that they just have to run the AC and the microwave at the same time. I mean, really? You can't turn of the AC for 5 minutes while you run the microwave?
2016 Coachmen Viking Legend 12RB A-Frame
2015 Jeep Grand Cherokee Summit w/Tow package
09-02-2018, 07:59 PM
#46
I start and run the AC, Dometic refrigerator, invertor and a few lights (LED). Turn the AC off and use the microwave for quick popcorn or meals. Not using the water heater unless needed for a shower. Turn AC off and let it heat the water for a few minutes, turn off, restart the AC and good to go. It's all about managing the watts.
09-02-2018, 11:43 PM
#47
Water heater in an Aframe is propane. If it lighting causes the system to shutdown you're running to close to the edge.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
09-05-2018, 02:25 PM
#48
Sorry, should have mentioned that the factory (?) SW10D (propane only) was replaced with a SW10DE (propane and shore) by the previous owner. I can see now how that could confusing.
09-22-2018, 12:05 PM
#49
I went to a welder and he installed a 2" receiver on the rear which supports a rack for my Honda 3000W 140 pound inverter and gas cans. Used it on 2000 mile trip and weekends with no trouble. Use a welder who works on trailers and you should not have a problem.
11-30-2018, 01:14 AM
#50
Northern Tool is running a sale right now where you get a free $200 e-gift card with purchase of $999 Honda EU2200i generator. Keycode 263176. Free shipping. E-gift card expires 6/30/2019. However I have found that you can use the e-gift card to purchase actual gift cards that have no expiration date. I got in on this deal this past June.
11-30-2018, 07:45 AM
#51
thanks for the note on Northern Tools $200 gift card.
I have been looking for a deal on a Honda generator for months.
Only regret is all the tools I needed for the new fiver are bought.
Can I use the $200 card to buy other gift cards?
03-14-2019, 04:45 PM
#52
Made it simple.
I took the Cool Cat off my existing 30 amp breaker/inverter and have a 30 amp extension chord safely connected into it.
When I RV park camp I just plug the extension cord into the duplex outlet that is at all RV parks or if I'm using a gen-set I just plug it into the gen along side the standard 30 amp plug that is typically on the HS A-Frame Pop ups.
I plan to connect the Microwave to this 30 amp modification as well. With 30 amps available they both should work fine.
Cost under $100 including the cord and the through wall ele access panel.
I have a 3500 KWH gen set I carry with me for boon-docking, lakes, and hunting. I built a sound deflector to block the noise but it really is not a big deal.
Doc
