Old 05-26-2015, 06:47 PM   #1
Generator that will fit under bed?
Looking to get a generator for dry camping/boondocking. Want it to be able to fit under the bed of an A122s so it can also serve to help take some weight off the tongue. Anyone else carry theirs in that location? Looks to be about 16.5" to close the bed down fully, 15" to be able to push it under the wood support member and further back. Anyone know a good generator that will fit this area?
2015 A122S
CJofWolfcreek is offline   Reply With Quote
Old 05-26-2015, 06:51 PM   #2
Ford Idaho's Avatar
I would never ever put a gasoline fueled device inside a living compartment much less under the bed.
Old 05-26-2015, 06:56 PM   #3
Stormrider151's Avatar
Just to clarify and I hope I already know the answer. But your talking about just transporting it there and not running it from that location. I know it's a dumb question but needed to be ask.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-26-2015, 06:59 PM   #4
I appreciate that. I wouldn't either. There are good propane adapter kits out there that I'd use so no gasoline would be in the camper at all.
2015 A122S
Old 05-26-2015, 07:05 PM   #5
I have a small 1000 watt 2 stroke I got on the Heartland website for the teardrop I'm building. I haven't used it yet but it would probably fit. You might look at some the small Honda's. Pricey but great generators.
Old 05-26-2015, 07:09 PM   #6
Yes stormrider, just for transport. As I said to help balance the tongue weight better. The A122s comes rather tongue heavy with dual propane tanks, the power tongue jack and just a single group 24 battery. Tried dry water tank and full water tank and there is no appreciable difference in tongue weight. We pack light so being able to shift weight rearward is pretty hard. We're right at 15%. My big LPG powered generator would be up in the back of the truck bed. I'm open to any other ideas to help bring the tongue weight down to give me a safety margin instead of being right at the max.
BTW, retired firefighter/emt here as well. 20 years as a fire fighter in the military and about 15 years as a volunteer with the fire dept and ambulance squad.
2015 A122S
Old 05-27-2015, 06:40 AM   #7
I would imagine a Honda 2000 or the similar Yamaha generator would fit under the bed, but you'd want to check the dimensions first! I'm looking to get the Honda, but haven't done so yet.
I wish mine had a single propane tank, just because of the tongue weight. I actually only have one of them filled to save a bit of weight.
There's no way I could use two full tanks of propane in a single trip! I'm still on my first tank after a year. I actually never even refilled the tank on my first popup, which I had for two years!
2014 Rockwood A122BH
2017 Nissan Pathfinder
bensinc is offline   Reply With Quote
Old 05-27-2015, 07:47 AM   #8
A Honda 2000 weighs 46 lbs. Given the proportions of the trailer, that is not going to make much difference on your tongue weight. And it is 16.7 inches in height. So it is probably out of considerations.
At 29 lbs the Honda 1000 will make less than ten lbs difference in tongue weight while the 15 inches height spec just fits your measurements.
I've thought about this too, let us know what you decide.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-27-2015, 07:53 AM   #9
Torch's Avatar
I have 2 Yamaha 2000's, either those or Honda's will work. Both neck and neck when it comes to quality.
Torch is offline   Reply With Quote
Old 05-27-2015, 08:11 AM   #10
Director, FROG
F.R.O.G.'s Avatar
Just my 2 cents worth, but I'd also not transport a gasoline generator in an enclosed trailer. I understand that you're not talking about running it in there, so carbon monoxide isn't an issue. But the sloshing of the gasoline as you travel, in addition to it's just sitting there, could rather easily create gas fumes that I wouldn't want to have around in an enclosed area when I start the gas range, furnace, or other flame-based appliances.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
bed, generator
« A122S Manual | UTV »
