Old 08-02-2015, 04:02 PM   #1
kdot's Avatar
Generator use
This is probably a dumb question, but I am new to generator use and want to do a lot of off-the-grid camping. My question is this: to use the generator, do I just attach the A122S 30-amp electrical cord to the generator's 30 amp outlet and run the cord to the inlet on the left side of the trailer? If so, is that all that needs to be done? I probably won't use the genie for more than lights and my wife's CPAP machine, possibly the furnace on cold nights. I may or may not try to run the AC off of it. Would all of this work, as long as I wasn't running a lot of stuff all at the same time? My Generator is the Honda EU2000i "Companion" model. Thanks in advance for your advice.
Kdot
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 08-02-2015, 05:17 PM   #2
That's it so far as connections go.
If it's just the interior lights you shouldn't need the generator to run them.
You do need the generator to run the a/c.
You don't need it to run the furnace.
rwarrin is offline   Reply With Quote
Old 08-02-2015, 05:26 PM   #3
kdot's Avatar
Generator hook-up
Thanks Kwarrin, that's what I suspected.
Kent
2017 RPod179
2016 Honda Pilot
Old 08-02-2015, 05:37 PM   #4
I should clarify when I say "you don't need your generator to do xxxx" I am assuming you have a charged battery.
Old 08-12-2015, 11:58 AM   #5
Kdot, I believe that the CPAP runs on 110ac, so you would need to run the shore power cord. If the CPAP can run on 12vdc, then hooking up the genie's 12v straight to the battery would be fine.
The easiest way to think about it is:
Hooked to shore power, run anything.
Hooked to battery, run only 12v things.
My 2˘
Jim
Jim n Shari is offline   Reply With Quote
Old 08-12-2015, 01:19 PM   #6
kdot's Avatar
Generator use
Jim and Shari,
I discovered that the trailer shore power cable would not hook up to the 30 outlet on the generator, so I used an adaptor to attach the cable to the 110 outlet on the gennie, and hooked it up to the connector on the side of the trailer. I'm assuming, from what you've said, that doing it that way won't charge the battery or power any of the 12v stuff. Am I understanding that correctly? I'm really not sure I've got the hang of using this thing yet.
kdot
2017 RPod179
2016 Honda Pilot
Old 08-12-2015, 01:46 PM   #7
The shore power line will power everything. Shore power goes into an inverter that charges the battery. When you unhook shore power all that you are left with is 12v.
Old 08-12-2015, 02:59 PM   #8
The Northern Tools site says you need two to power A/C
  • 120V, 2000 Watt max.; 1600 Watt rated output
  • One 20 amp 120V outlet and one 30 amp, 120V outlet which allows connection to another EU2000i to double the power
  • GX100 OHC engine
  • Will power most RV rooftop AC units when used in parallel with another EU2000i generator.
  • I don't know anything about generators though I had thought about getting a small one, but my A frame does all I need on shore power.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 08-12-2015, 03:06 PM   #9
Phat Phrog Stunt Crew
elind's Avatar
The genny will power up the 120 volts and power the converter to use 12 volt power plus charge the battery.
If you have a good battery system you may be able to run a Cpap system with the use of a inverter plugged into to a 12 volt.
The Honda 2000 Companion needs an adapter from the 30amp plug to the 30 amp cord to the TT.
If you have a surge protector in the line you will need an adapter to allow the floating ground to be tied to the neutral of the generator. If you don't do this the surge protector will think there is a problem.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-12-2015, 03:18 PM   #10
That is a QUALITY Generator - and amongst the Quietest. (If you are looking to run it at night for Wife's CPAP, that will be IMPORTANT - unless you want the Ranger to come knocking to INSIST that you Turn It Off; or a Neighbor to simply walk over and Turn It Off.) If you ARE going to Dry Camp or Boondock, you really SHOULD get a 12V CPAP Machine. With a 110V CPAP System, if the Genie dies (mechanical issue or gas or ...) then you really have very few options but to pack-up in the middle of the night and make a drive to a Power Outlet. With a 12V System, you can power it from Genie or Battery (double-up your TT Batteries for even more insurance) or even the Car Battery. And all can sleep soundly knowing you have backup options and the Genie doesn't have to Break Curfew!!
Your Honda will possibly run your AC, but more likely not unless it is one of the smaller 10K units put on A-frames and smallest PUPs. Your Battery will run the Lights and the Furnace for the Night (maybe 2-3 if you are thrifty). Your Genie will be needed for a Microwave or Hairdryer or Coffee Pot - but if you run the Genie for Midnight Popcorn then you'd better expect Company...
Pup: '11 HW-296
TV: '09 RAM 1500 Hemi 4x4 CC
seigell is offline   Reply With Quote
generator
