Old 05-17-2013, 10:55 AM   #1
kixonrt66's Avatar
Getting ready for the camping season
Hello All,
I have had my 122BH winterized during the cold weather and we are ready to get it prepared for the camping season. I have charged my battery, but I am a complete newbie regarding the other tasks needed to get my camper ready for the road. Could anyone post a list of things to be done and a short description of how to do them when required. I need to know how to properly fill the camper with water making sure that the water heater is filled and all of the valves are in their proper positions. I also need to know how to test the water heater, water pump, etc. prior to hitting the road. Also, do I need to grease the wheel bearings for the season?
Many thanks in advance for your help with this information!
Kix
2006 Toyota Tacoma Pre Runner
Rockwood A122BH
kixonrt66 is offline   Reply With Quote
Old 05-17-2013, 03:26 PM   #2
wyo700's Avatar
The first thing I would do is hook the water up to the city water and open all the faucets and get all the pink anti freeze out. Then I am sure you by passed your water heater so turn the valves back in the summer position so you can fill hot water tank. Then open the pressure relief valve on your hot water tank to get all the air out when filling the tank by opening a hot water faucet in the camper.. Then once water is coming out close the valve and let the tank fill. Then turn on propane and purge out lines by turning on the stove till you get it to light and then light your hot water heater let it warm up a bit and check for hot water at faucets.
Yes putting some grease in the wheel bearings wouldn't be a bad idea.
Good luck!!
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 05-17-2013, 03:36 PM   #3
kixonrt66's Avatar
Camping Season
Many Thanks wyo700!!!
That's just the information I was looking for! I appreciate your taking the time to help out.
Kix
Rockwood A122BH
Old 05-17-2013, 04:56 PM   #4
Mostly Harmless
thehamguy1's Avatar
Don't put TOO much grease in the bearings, it's possible you could blow out the grease seals in the hub. Grease will then migrate into the brake drum and bye-bye brakes. Don't ask me how I know (ok, I'll tell: lost brakes in mountains in Alaska last summer, repair shop in Anchorage said too much grease in the hub blew the seals, and they see that a lot with campers that have the hubs like ours). Just a squirt or two should do it.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 05-19-2013, 01:35 AM   #5
kixonrt66's Avatar
Too Much Grease
Many Thanks thehamguy1,
That is good information and I will follow your hard earned wisdom. We are heading up to southwest Colorado over the Memorial Day weekend to visit one of my absolute favorite camping spots just east of Durango near the Vallecito reservoir. Very pretty country for sure.
Thanks for the advice!
Kix
Rockwood A122BH
Old 05-19-2013, 07:01 AM   #6
Mostly Harmless
thehamguy1's Avatar
Oh man, Kix, I wish we were going along! We've had many happy camping experiences in Colorado and New Mexico, though not in the area you're headed for. Please have so much fun that you have extra to give away!
2011 Rockwood A128
60W solar system
Old 05-19-2013, 08:03 AM   #7
Herk7769's Avatar
Going to dewinterize.
This is how I do the plumbing...
HAM CALLSIGN - KC3FFW
Old 05-20-2013, 10:04 PM   #8
kixonrt66's Avatar
De-Winterizing
Many Thanks to all for the great advice! I have completed my de-winterizing procedure and everything looks good! I have my camper plugged in to power in my driveway and everything is working great...water system, water heater, faucets, shower, drains, lights, A/C and Heat systems, stove and grill, microwave, radio, furnace, leak check on the roof, greased wheel bearings (lightly), lubed and checked hitch and associated equipment, brakes and brake lights work well. Nw...if I could only get my refrigerator to work!!! AAARRRGGGHH!!! I can't seem to get it to work no matter what I do. Plugged in to 110 power it should start to work pretty quickly, right? Any suggestions?
Kix
Hamguy,
I'll post some pictures from this weekend if I can. SW Colorado is truly beautiful!
Rockwood A122BH
Old 05-20-2013, 10:22 PM   #9
Herk7769's Avatar
"Pretty quickly" --- Not.
Using shore power, it could take from 8 - 12 hours to cool an empty fridge.
I put bag ice in the freezer, and turn it on the night before I plan on loading it.
FYI - Propane is a more efficient heat source so if you are cramped for time, switch it to "gas only."
Old 05-20-2013, 10:37 PM   #10
ko777's Avatar
I had a problem like that and I found out that the power outlet to the fridge was dead by connecting a power drill to it. All I had to do was to reset the GFCI outlet. I hope that is the case...
Good Luck.
ko777 is offline   Reply With Quote
