Old 10-22-2012, 04:54 PM   #1
Mostly Harmless
thehamguy1's Avatar
I'm plodding along on the winterizing, doing a bit here and there. I'll store it outside this winter; the garage I rented last year was getting too expensive.
Gonna use an ADCO cover and needed to do something to keep the camper's sharp corners from tearing it. Following a tip from the forum, I'm making corner pads from sections of foam pipe insulation and holding them on with 2" blue painters tape. I'll see if it holds all season. If it leaves a residue ill clean it with Goo Gone.
I also made covers for the fridge vent area from half-inch foam board. Will cut a piece to cover the Cool Cat's exterior grill too.
ID:	20947   Click image for larger version
ID:	20948   Click image for larger version
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 10-22-2012, 05:11 PM   #2
Rockwood Premier A126
gregory's Avatar
Neat job on the corner protection!
Question time:
Are you planning on using padding of some sort to protect the bubble windows from scratching under the cover? Or would that even be necessary?
Are you using that metal outlet cover for the AC condensation drain underneath?
Looking forward to your future posts for chronicling your process/progress. It's getting to be that time of year.
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 10-22-2012, 05:23 PM   #3
Mostly Harmless
thehamguy1's Avatar
I've been hoping someone on the forum would have an idea about protecting the bubble window. I suppose I could tape a chunk of old bedsheet over it before putting the cover on. I haven't taken the cover out of the box yet so I don't know what the inner layer of it is like, whether soft or abrasive.
I did put the cover plates back on the A/C drain and the drain in the fridge area. Those drains are pretty flimsy; a creature would have no trouble popping out the perforated center.
2011 Rockwood A128
60W solar system
Old 10-22-2012, 05:50 PM   #4
ko777's Avatar
Thanks for pointing out the corners. I'm double tarping my rig so any movement will be against the inside tarp. The tarp underneath will be smaller then the tarp above it. I'm using a plastic table cloth from the dollar store to cover the bubble windows, the material is very smooth and with the 3 later protection, it shouldn't scratch the surface. Make sure to give a good cleaning before covering.
I like the ideas I get from this forum, awesome!
ko777 is offline   Reply With Quote
Old 10-22-2012, 06:17 PM   #5
Winterized and put the cover on Yesterday. I was a bit depressed.
Tarcon is offline   Reply With Quote
Old 10-22-2012, 08:21 PM   #6
Mostly Harmless
thehamguy1's Avatar
And we probably have to store our motorcycles next. I feel your pain.
2011 Rockwood A128
60W solar system
Old 10-23-2012, 04:57 AM   #7
Warm week here. Went for a motorcycle ride on Saturday. Looks like we can get out on a ride this Saturday. Might be the last.
Old 10-23-2012, 05:09 AM   #8
I also plan to cover up the camper this week. Was really hoping for one more campout but not gonna happen.
2017 Rockwood A213HW
2017 Chevy Colorado Z71 4x4 V6
backpacker3 is offline   Reply With Quote
Old 10-26-2012, 08:11 PM   #9
Yukon Don's Avatar
I had plans for getting out one last time this upcoming week but the last two weeks have been cold and rainy. A winter storm warning (somehow they always manage to predict those accurately) sealed the deal and I very reluctantly covered her over and wrapped approximately seven miles of rope around the whole affair three days ago.
She now sits covered in snow.
My off-season projects will include:
-shivering
-wishing for spring
-(there may be more of my ongoing experimentation to build the perfect hot buttered rum...)
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 11-01-2012, 02:10 PM   #10
Hi, I'm new to the forum and hope this the appropriate spot for this question.. I am getting ready to winterize our A122 a-frame. I want to buy a winter cover and have a question about size of cover to get.. Most ADCO tyvek covers say they come in an 85" width. Our A122 measures at 86 inches wide . .If you have an A122 and have a winter cover, what size fits? Thanks ..
Charlie Ross
crossinlan is offline   Reply With Quote
