Old 03-30-2015, 11:57 PM   #41
handbuilder's Avatar
A couple zip ties, a steel plate and magnetic hooks provide a spot for our coffee cups off the counter and out of the way.
Also used magnet attachment to hold the dish sponge by the sink
Name:	2015-03-29 18.54.18.jpg
ID:	72591   Click image for larger version
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 03-31-2015, 12:03 AM   #42
I use Gear Ties here for keys and eyeglasses - this makes them easily found and safely kept
Old 04-25-2017, 10:37 PM   #43
For Thegirlfromlimberlost:
You might check post #31 in this thread. It is a nice adjustable storage shelf unit that fits well over the stove cover. Extremely affordable and stable. A couple photos more to show it in use.
ID:	135925   Click image for larger version
Old 04-25-2017, 10:59 PM   #44
A few other ideas to show how easy it is to personalize your A-Frame without sacrificing precious counter space or floor space and the ideas are fuss free. Easy peasy to make changes in decor in a small space
ID:	135927   Click image for larger version
ID:	135928   Click image for larger version
Old 05-12-2017, 05:49 PM   #45
A frame camper mods
We added shelving brackets that are attached through the metal window frame. Threaded screw bolts with nuts on both sides to offset the bolt head to hang and remove the shelving brackets. Curtains with blackout material on backside and insul-bright sewn in the middle to help keep out the heat & cold. The shelving will fit on the rear bed or behind the mattress it does bounce and move if not secured laying on the matress
ID:	137655   Click image for larger version
ID:	137656   Click image for larger version
ID:	137657   Click image for larger version
ID:	137658   Click image for larger version
OGUYSRULE is offline   Reply With Quote
Old 07-02-2017, 10:22 PM   #46
Wall decals
How are your wall decals holding up? Are they staying on the textured walls ok? I was going to use them but wondered if they would come off with the added humidity of summer. You have done a great job on your decorating. I have decorated our A213HW but don't know how to post more than one photo.
Dee Silbaugh is offline   Reply With Quote
Old 07-05-2017, 01:50 AM   #47
Vinyl artwork is still up, doing great. I suppose it would also depend on having a clean surface and how much adhesive is on the decal.
