Old 08-10-2015, 02:49 PM   #1
trailergirl99's Avatar
Glass Stove Top Hinges
Hi everyone,
Did a search and can't seem to find any solution. When I went to open her up for my last trip out (only 3rd trip since buying it), the nut and bolts for the hinges on the glass stove top cover had broken off. I didn't notice right away and when I went to open the cover, the rear hinges also broke off. My brother had the same issue on his Rockwood Fifth Wheel...any ideas? I can't seem to find anywhere to just replace the nut and bolt.
2015 Rockwood A122s
2015 Jeep Grand Cherokee
trailergirl99 is offline   Reply With Quote
Old 08-10-2015, 07:05 PM   #2
Back to the dealer, that's not right on a new rig.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 08-11-2015, 06:21 AM   #3
MinneweeseMI's Avatar
It seems like a lot of people have this happen.
range top glass cover on an A122s
Mark and Dawn
Michigan
2014 a122s
2014 Tacoma Double Cab
MinneweeseMI is online now   Reply With Quote
Old 08-11-2015, 08:45 AM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
Can't you just replace with metal nuts and bolts?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 08-11-2015, 09:58 AM   #5
Not likely, glass on metal and tight enough to hold would probably not work too well.
Loctite might help, or just stab the nut and thread where they meet with a hot screwdriver.
Mark and Dawn
Michigan
2014 a122s
Old 08-12-2015, 07:50 AM   #6
frozen's Avatar
Since the center hinge on glass tops operates in the opposite direction from metal tops, it's not unlikely that someone has tried to open it by folding it the wrong way. Something has to give.
frozen is offline   Reply With Quote
Old 08-12-2015, 11:18 AM   #7
I have never used the stove, opened the glass cover once during my pdi and that's it. I have only been out 3 times, even if it was user error is it still not acceptable that the nuts would shear off after such a short time.
2015 Rockwood A122s
Old 08-12-2015, 07:12 PM   #8
It worked!
I followed the advice of the experts here and tried the hot screwdriver solution and found that it works perfectly. I had one nut that come off completely and fell under the drip pan beneath the burners and another one that was ready to come off. I tightened all of the other bolts carefully then seared each with the hot screwdriver and let them cool. I could not loosen any after that.
magpi26 is offline   Reply With Quote
Old 08-25-2016, 04:31 AM   #9
Mark and Dawn
Michigan
2014 a122s
Old 08-25-2016, 08:57 AM   #10
jeff
jeff64's Avatar
You can source nylon nuts and bolts in a variety of head style and in black too, from McMaster-Carr. They're an industrial supply house, nationwide. Doubt that they will sell you 1 or 2, probably 10 or 25 pk, but if you know what you're looking at/for they'll have it. Don't know about the hinges, you may have to go to Suburban or your dealer
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
