Old 03-25-2016, 03:15 PM   #11
Originally Posted by nursecrickett View Post
I have a black screw on thing that screws onto the camper side exit water point. It is hard plastic and has a hollow open center. Theres another black male rubber thing that fits into it that has a few protuding notches on it, but no threads for a hose to screw into.
That is the adapter that was delivered with the camper. It has a barbed end to use with a cut off hose and clamp. It will work perfectly well or you can get that 3/4 MHT Valtera adapter as most others do.
The outlet is up high, just behind the sink. It is a 1.5 inch MPT outlet with a cap on it. The Valtera linked above will fit on it or you can use a 1.5 inch elbow and sump pump tubing like the one in the OZandUs photo.
I like the OZandUS system, but use a garden hose instead of the big tubing he uses. I normally us the smaller 4 gallon Aqua-Tainer since I generate very little water. It stows nicely in the front storage trunk or the truck bed, until i get home.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 03-25-2016, 05:40 PM   #12
DanM-AZ's Avatar
Vinnie, what parts do I need for your set up and DanM, will that valterra screw on part you recommended work with his hose setup or would I need something different?
Thanks to all!
nursecrickett,
I just use that with a real short standard hose that I drop into an Aquatainer parked on the side of the trailer. No special fitting at the Aquatainer needed. In fact, with the hose dropped into the large opening of the Aquatainer, there's more than enough room around the hose to allow easy air displacement as the water enters the container. That helps the sink drain as it is supposed to.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 03-25-2016, 11:44 PM   #13
handbuilder's Avatar
Our sink drains using a garden hose and a vented attachment. He made a small kit with sewer lids and Aquatainer for either campground hook up or dry camping use
ID:	102867   Click image for larger version
Name:	2013-07-19 14.59.06.jpg
ID:	102868   Click image for larger version
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
water
