Old 03-24-2016, 03:19 PM   #1
gray water exit point
Hi there,
Used my new to us 2012 Rockwood A126 for the first time a few weeks ago. Went to hook up a hose to a bucket to catch the gray water from the sink. No go.
I have a black screw on thing that screws onto the camper side exit water point. It is hard plastic and has a hollow open center. Theres another black male rubber thing that fits into it that has a few protuding notches on it, but no threads for a hose to screw into.
What exactly am I supposed to have there at that exit point for the sink water?? Do you know where I can get it?
Camping World was no help. Said theyd never seen such a hookup.
Help appreciated!
Thanks!
Crickett
nursecrickett is offline   Reply With Quote
Old 03-24-2016, 03:33 PM   #2
hammer55's Avatar
pictures would help everyone
Originally Posted by nursecrickett View Post
Hi there,
Help appreciated!
Thanks!
Crickett
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-24-2016, 03:45 PM   #3
Oaklevel's Avatar
Hard to tell without pictures but if you want to attach a garden hose for grey water dump port you will probably need to buy an attachment at an RV store most like myself do not have one...........
Was your trailer used at a permanent site at one time???????
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-24-2016, 04:48 PM   #4
DanM-AZ's Avatar
Here is what you need:
Valterra T01-0091VP 1-1/2" x 3/4" 90 Drain Connector
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 03-24-2016, 05:32 PM   #5
Vinnie's Avatar
I want to use a 7 gal aquatainer like this but the drain plug on the rockwood is under the frame lower than the top of the aquatainer still trying to find a solution I wonder if setting the aquatainer on its belly would be a problem if its a tight fit there shouldn't be a problem with leaks.
Name:	Single Tank Grey Water Collection.jpeg.jpg
________________
Rockwood A214HW
Vinnie is offline   Reply With Quote
Old 03-24-2016, 06:35 PM   #6
DanM-AZ's Avatar
Vinnie,
I think that you will need one of these:
http://www.amazon.com/Barker-Manufac...apparel&sr=1-2
or these:
http://www.amazon.com/Tote-N-Stor-25...3JDP9VJ7C8YR1V
or this one:
http://www.amazon.com/Tote-N-Stor-25...CJGEMCAKYRH8HZ
Dan
Old 03-25-2016, 08:34 AM   #7
I would think that if you set up the way you have in the picture it would work kind of like a trap on a sink. There would be a little water in the drain hose but all of the other waste water would end up in the container.
FarNorthCamping is offline   Reply With Quote
Old 03-25-2016, 12:19 PM   #8
OMG PERFECT!!!!! Thank you DanM!!!
Old 03-25-2016, 12:25 PM   #9
What parts needed for that set up?
Vinnie, what parts do I need for your set up and DanM, will that valterra screw on part you recommended work with his hose setup or would I need something different?
Thanks to all!
Old 03-25-2016, 02:22 PM   #10
Vinnie's Avatar
Thanks to all!
That's not my setup but one that I might try I found it on the popup forum here
3rd post down from OZ and US click on pictures they explain how to build the system
Another grey water question...
OZ and US pics and other camper Mods here
https://picasaweb.google.com/1149655...20166289121538
Hope that helps
________________
Rockwood A214HW
water
