Old 07-14-2016, 12:19 PM   #1
Grey water drainage
Has anyone devised a way to connect a hose from the external sink drain to the sewer pipe at an RV park/campground?
JC Slugger
JC Slugger is offline   Reply With Quote
Old 07-14-2016, 12:24 PM   #2
what does that mean?
doesn't your external sink drain into a holding tank?
Do you mean your outside kitchen?
or do you have some other setup???
mkosu04 is offline   Reply With Quote
Old 07-14-2016, 12:40 PM   #3
drain
there is an opening on the outside of my A122 that comes from the sink drain. Most people put a bucket out but I want a closed system.
Old 07-14-2016, 12:59 PM   #4
Get yourself one of these and a hose.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 07-14-2016, 02:12 PM   #5
ilmor's Avatar
I have learned something new.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-15-2016, 12:47 AM   #6
Just make sure you have a long enough hose to go to the sewer fitting to allow some drain water to collect at a low point to minimize chances of sewer gasses entering your trailer!
Phillip in Scenic New Mexico
2016 T21TBHW
2006 Toyota 4Runner
ptchap is offline   Reply With Quote
Old 07-15-2016, 12:58 AM   #7
I used one of these for 20 yrs with my popup:
Barker 10887 5 Gallon Original Tote-Along Portable Holding Tank | American RV Company
Uses a short double ended, regular female fitting, hose.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 07-15-2016, 06:37 AM   #8
mudman2's Avatar
How are u venting the setup to keep water flowing. Does the vent on the container do it?
2015 t19qbhw
2015 Toyota Tundra crewmax lmtd
2015 Flagstaff t19QBHW
2015 tundra
mudman2 is offline   Reply With Quote
Old 07-15-2016, 06:45 AM   #9
Several people I camp with use 5 gallon water containers, like the one below, for their outdoor sinks. They work well and, depending on use, can last a couple days.
Gerry can
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 07-15-2016, 10:08 AM   #10
2015 t19qbhw
Hmmm. Good question. I don't recall a vent, as I would remove the hose and there was a plastic cap that pushed over the threads on the cap when I took it to dump it. I never had a problem with venting, though.
I actually more of a problem with the drain line in the popup kinking once in a while (it was a "swing level" galley; not a flip-up).
drain, grey water, water
