Old 07-16-2012, 06:39 PM   #11
Cleancut...
Have you not tried to run the Cool Cat off of your 2,000 wattt generator?
Maranatha is offline   Reply With Quote
Old 07-16-2012, 07:37 PM   #12
I just came across the following post by Mike G which says that he was able to run a Cool Cat 10,000 BTU off of a 2,000 watt Yamaha generator.
Originally Posted by Mike G on 03-19-12:
"I just purchased a Yamaha 2000 watt generator and it runs my Cool Cat fine. I copied a post about the generator below.
Well I fired up the new Yamaha generator and it started on the first pull! This thing is super quiet and easy to use. I was loading my camper back up for the year and hooking everything back up, so I decided to see if the generator would run the AC unit. The generator never even flinched, it stayed in Eco mode and I even turned on the lights and roof fan.
The Yamaha 2000 watt will run our 10,000 Cool Cat!!!
I am glad I did not buy a bigger generator, this thing is not extremely heavy, but I would not want to carry or move anything heavier."
Old 07-16-2012, 10:35 PM   #13
That's great that the Yamaha will run it. I doubt the Champion will run it but I will give it a try. I don't pick up my trailer until Saturday and Sunday is the earliest I can try it.
hammick is offline   Reply With Quote
Old 07-17-2012, 03:37 AM   #14
Maranatha, On my unit, I have a 2013 rockwood a122, The champion generator will not run the cool cat. It will run the microwave, but thats about it. Had I known that the Yamaha 2000 would have run the ac I would of paid the extra $$$ for ir.
cleancut39 is offline   Reply With Quote
Old 07-17-2012, 07:00 AM   #15
Cleancut,
Hmmm... If a Yamaha 2,000 will run it, I'm thinking a Champion 2,000 should run it. This may be a YMMV (Your Mileage May Vary) type of thing. Let's see who else will chime in here with there generator experience/opinions.
Old 07-17-2012, 07:47 AM   #16
I have the a122 and a honda 2000 runs the cool cat just fine.
dansa122 is offline   Reply With Quote
Old 07-17-2012, 08:04 AM   #17
Dansa122..... Welcome to the Forum. Even though the ratings are the same I think that the Yamaha and the Honda have more power. We should know Saturday or soon there after how Hammick made out with his.
Old 07-17-2012, 04:04 PM   #18
honda, yamaha or kipor ...
all three will run the heat exchanger on cool ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 07-17-2012, 06:05 PM   #19
I have the 10,000 A/C and a yamaha 2000 watt gen. The gen will start the a/c at my house which is 1,500 feet elevation. It struggles but it does start it. Once it is running, it's fine. All the load is right when you fire up the a/c initially.
have not tried this in the mountains, I am guessing because the gen is not as efficient at high elevation, it may not work.
maniac28 is offline   Reply With Quote
Old 07-17-2012, 09:00 PM   #20
Well I found out today from Forest River that the deck on the front is only rated for 650lbs. My ATV weighs 850lbs dry. Also they told me I should expect that 90% of the weight of the ATV would be transferred to the hitch. I think my Cherokee will be outgunned even with a good WDH. Back to the drawing board for us. I will have the generator probably tomorrow so if anyone is in Kansas City with a Cool Cat drop me a PM and we can test it with my generator.
