Old 06-01-2012, 03:17 PM   #11
Triguy's Avatar
Here you go ...
Taking Delivery Tomorrow..What to look for?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-02-2012, 03:28 PM   #12
Hello:
I have a question. Since I didn't receive an owners manual to my A Frame there is a switch I don't know the purpose. It's just to the right of the electrical fuse box, just like a light switch but in the up position has a small red light. I have no idea what it's for. the rest of te components have been working nicely.
djtouchfla is offline   Reply With Quote
Old 06-02-2012, 03:29 PM   #13
Originally Posted by djtouchfla View Post
Hello:
Water Heater
2012 Flagstaff T-12DD
2004 Chevy Suburban
2000 GMC Sierra Z-71
loganmartin is offline   Reply With Quote
Old 06-02-2012, 03:59 PM   #14
Mostly Harmless
thehamguy1's Avatar
It's as LM said. I'll add: don't turn it on unless the water heater is full of water. Probably a brief on/off blip won't hurt. Since you don't have a manual (?) I should also mention that there's a water heater bypass built into the water lines, so when you want to fill and use it you'll have to close the valve on the bypass and open the two valves on the water heater's in and out lines. Once the water heater is full you just turn on that switch and it's automatic from there on. You'll need to have the gas on too, the heater is gas only. Ours is very quiet--you have to listen close to hear it operate. It's very nice to have hot water from the tap.
The dealer should include the water heater operation including the bypass location in the final walk through. You might have some luck contacting FR and asking to get an owners manual. Anyone else here have a number to call at FR? I vaguely remember a posting about someone contacting FR customer service about an A-frame issue and getting a positive outcome.
Open the heater's outside access door and ensure that the anode rod has been installed before trying to fill the heater. The anode rods are often left uninstalled--and rattling around inside the access door--when the heater is not filled. We leave ours out between camping trips so the heater will dry inside (we put the water system back in bypass mode then, of course).
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-03-2012, 04:32 PM   #15
Rockwood Premier A126
gregory's Avatar
Maybe this link will help.
Who to contact at georgetown
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 06-04-2012, 08:17 AM   #16
Thank you for the information. I gave it a go and all works fine.
David Touch
The Villages Fl.
Old 06-06-2012, 10:53 AM   #17
We want to thank each person who responded to our request... each one of your responses was valuable in helping us get the info we needed before purchasing our A-frame. Our order has been placed with Tropical RV in Ft. Pierce, Fla... and now we get to wait the 4-6 weeks before it arrives.... sheeeesh!
In the meantime, we're checking out campsites on the central and northern east coast of Florida.
Will let you all know how things go.....
Frank and Marje
oomiak is offline   Reply With Quote
Old 06-08-2012, 05:17 PM   #18
that's awesome...congrats!
2004 Chevy Suburban
a-frame, a122, a122bh, rockwood
