Old 06-18-2019, 05:03 AM   #1
TinTeepee
High wall door trim
It seems that the door on my hard side high wall falls through the door opening when traveling causing the door trim to bend on the latch side towards the bottom of the top door. Looking for a way to prevent this from happening. Any ideas or experience with this problem?
TinTeepee is offline   Reply With Quote
Old 06-18-2019, 06:57 AM   #2
OYO
OYO's Avatar
That's kinda hard to imagine. There should be a ~1/2" flange around the door.
Can you post a photo?
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
OYO is online now   Reply With Quote
Old 06-18-2019, 07:26 AM   #3
TinTeepee
Photo below
Sorry the photo is sideways. Shows where I have straightened the door flange.
Old 06-18-2019, 08:05 AM   #4
OYO
OYO's Avatar
I'd bet big $ that the piano hinge that connects the upper triangle wall to the lower wall has come loose. Not uncommon.
Craig
Old 06-18-2019, 10:03 AM   #5
TinTeepee
Been there, done that.
I already tried that as well as checking the screws on the door hinges. The piano hinge screws are tight and I replaced the screws that were loose on the door hinges with pop rivets. I am thinking about adding an extension/reinforcement on the door flange. (I always tighten all accessible screws before the season begins and use wooden toothpicks and time bond white glue to fix any stripped holes.)
Old 06-18-2019, 11:53 AM   #6
OYO
OYO's Avatar
Well i guess i lost big $. That's why I dont gamble.
I have no idea what could be the issue.
Sorry.
Craig
Old 06-18-2019, 12:22 PM   #7
Is your front wall separating from the cabinets? This would enlarge the door opening. It's a tragic but common problem with some HW campers.
If that's the case, your door is "too small" for the now stretched opening, and on the road flexing will open and close the gap, thus crunching your travel door.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 06-18-2019, 02:51 PM   #8
HW door issue
Have same issue. Resolved it by folding a dish towel a couple times over then placing it between the door and jam after I take down the sides. Have never had a problem since doing this.
NormTn is offline   Reply With Quote
door
