Old 07-30-2017, 12:28 PM   #21
The 2 side ends I installed a small stainless eye bolt to tie off to. Just check inside to make sure nothing is inside where you want to drill.
You never know what you know until you ask someone!
timfuji is offline   Reply With Quote
Old 07-31-2017, 08:32 AM   #22
BJR
Looks great thanks! That gives me some ideas.
BJR is offline   Reply With Quote
Old 08-31-2017, 06:51 PM   #23
Name:	ImageUploadedByForest River Forums1504219514.769919.jpg
ID:	150220Click image for larger version
Name:	ImageUploadedByForest River Forums1504219667.125046.jpg
ID:	150221Click image for larger version
Name:	ImageUploadedByForest River Forums1504219752.887677.jpg
I mounted a pivoting "D" ring (Harbor Freight) at the peak of the roof to attach triangular sail/sun shades (Costco and others). A carabiner attaches sails to D ring. Carabiner can be attached to the D ring prior to raising the roof into place or, snapped on after the roof is raised by standing on a step ladder. I used 4' X 2" ABS plastic pipes with a cap and a bolt to attach lower ends of sail/sun shades with paracord and bungees to ground spikes. The ABS pipes give added walking height under the shade "tent" that is created. I cut 4 triangular "teeth" (with a saw) into the bottom ends of the ABS pipes to keep the bases from slipping during buffeting in the breezes.
With a little practice, it is fairly quick and easy to put up and especially, take down, when a big wind comes up! I leave the peak connected and roll up the base of the triangles on each other. Put a bungee around the roll and attach it to the roof handle and the distal ends can be secured with a bungee to the bumper (if taken to the back) or the front frame (if taken forward). The triangular shapes of the shades work perfectly with the shape of the A frame and almost look like they were made for this application! Have been extremely happy with the results! Very inexpensive overall: 2 sails, D ring, ABS pipes/caps/bolts, paracord, bungees...under $75.
Only downside are the parks that don't allow spikes in the ground to protect sprinkler pipes from being punctured. In those cases, I have used the tow ball on my vehicle and a heavy picnic table to secure the ends of the sails. Not ideal but, when shade is needed, one gets creative. We have been attaching 3 short strings of "chili" lights to the edges of the sails with small binder clips placed every 18-24"...looks great at night!
SeaKnight46 is offline   Reply With Quote
Old 10-25-2017, 03:29 PM   #24
Retired and Relaxed....
Hello we are new on here.....nice to meet you all.
I too am looking for a awning for our Rockwood Hard Side....I am not really that fond of the Eye Brow style..it looks pretty flimsy....and other ideas ?
Greg
dutchtowneagle2 is offline   Reply With Quote
Old 10-29-2017, 09:14 AM   #25
I like the 12x16 tarp idea...does the door open OK with this tarp on since it is above the roof line when open?
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 10-29-2017, 12:02 PM   #26
Peak Sun/Sail attachment
Hello,
We are thinking of doing the same thing.....using the Peak to attach a Sun/Sail shade awning to our A frame....it's seems nice and economical. we are thinking of using 2 adjustable 8ft. tent poles and 2 guy ropes then on each pole to tie down to....should work....any ideas will be welcomed ? I think this setup gives one many, many different ways to go with different sizes Sunsails...
Thanks,
Greg
Old 09-25-2023, 09:14 AM   #27
Diy tarps for a frame campers.
I purchased stainless lifting eyelets from Amazon and placed them at all 4 corners
And both ends of the peak. They are 25 mm of so not very obtrusive. I bought “female” eyelets that are treaded for a bolt to come in from the back. I used truss head machine screws. These are low profile and smooth. The heads do not get in the way of anything. Yes you have to drill a hole for each eyelet. I backed the treads and the hole with butyl rubber so no leaks. These provide a great way to attach the peak of a tent shaped tarp at the peak and a tie down point for guide lines to polls.
ID:	293288   Click image for larger version
ID:	293289   Click image for larger version
ID:	293290   Click image for larger version
Kirk E is offline   Reply With Quote
Old 09-25-2023, 10:05 AM   #28
Nice area of cover!
I used to do similar when I had a PUP.
Just keep in mind, (especially with the bigger blue tarp) it WILL fill with water without a center pole(s) and it WILL become a sail in high winds and will easily pull out common tent stakes. Been there, done that!
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-25-2023, 10:07 AM   #29
Gramps42's Avatar
Homemade Awnings for A Frame
I sold our EZ up canopy for a Clam Quick Set screened canopy. It’s lighter and at campgrounds with mosquitoes, it’s a lifesaver and sets up in less than 60 seconds!
[ATTACH]293293
Roy
80 & Still Camping
2019 Rockwood 214HW
2011 Toyota Highlander
Gramps42 is offline   Reply With Quote
awning, frame, a-frame
