Old 08-29-2011, 04:12 PM   #11
On iPad. Click the share button at top of vid. Then cut&paste the link out of the email that pops up.
rawlus is offline   Reply With Quote
Old 08-29-2011, 04:23 PM   #12
Mostly Harmless
thehamguy1's Avatar
Very helpful. Thanks!
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 08-29-2011, 04:24 PM   #13
Herk7769's Avatar
Ditto! Awesome tip!
HAM CALLSIGN - KC3FFW
Old 08-29-2011, 06:25 PM   #14
Hamguy, I really like your ideas. I also have the A128 and so far am loving it. Although I would be nervous to make any permanent changes to mine, we may have to use some of your ideas. I love the screen door. I hate that heavy front table and am looking for ideas for a replacement. We are even thinking tv trays. Now, you need to come up with an easy attached awning. Please keep posting any other mods you do.
gsocamper is offline   Reply With Quote
Old 08-29-2011, 07:56 PM   #15
cudos ...
Cudos to your mods and sharing ideas Hamguy ... great stuff.
I just have question or two about your solar panel system that shows in your screen door video. I too run solar in my unit .. using an 80 watt panel/charge controller and a dual battery setup. I however run my panel directly to the charge controller which inturn is connected directly to my dual batteries on the tongue. I notice your wiring is channeled directly into the converter area of your trailer. Is there a specific reason for this ...or have you just mounted your charge controller permanently next to the converter and wired it out to the battery.
My A122 is up in the driveway now .. so I can post pics of the battery box holder that i installed ... and the solar setup i have now ... as it takes a few minutes to install and maybe helpfull for those others who wish to use this trailer to its fullest extent.
cheers .. d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 08-29-2011, 08:20 PM   #16
Mostly Harmless
thehamguy1's Avatar
We'd love to see pictures of your arrangement. Where did you get the 80 watt panel(s)? Ours are 45 watt units, so at full sun they only supply between 3 and 4 amps to the charge controller. The controller, BTW, is installed in the new storage unit I built, and the wire from the panels to the controller just runs through the outside shore power port for convenience sake--I didn't want to make any more penetrations of the floor or walls than the factory made.
I'm interested in your dual battery setup, so any info you can shoot me on that will be appreciated. My wife just read your message over my shoulder and said I should tell you to write an entire chapter on it! She's subject to fits of enthusiasm, bless her.
2011 Rockwood A128
60W solar system
Old 08-29-2011, 08:59 PM   #17
Mostly Harmless
thehamguy1's Avatar
Thanks, gsocamper. I guess all those years of shop classes did some good. Most of the things I've made so far are based on someone else's ideas I adapted. So here's a suggestion for the table replacement you can adapt. One thing we were considering doing before we settled on cutting our table in half and changing the table base was making a replacement plywood table that would fold in half lengthwise, then the folded table would fold down against the forward wall. I had a table like that on a sailboat once.
One problem to solve would be how to attach hinges securely to a wall as thin as the front one. It might be that if you took out the front speaker you could get access to the space between the front wall and the steel diamond plate "bow" of the camper. If so, you could through-bolt a cleat to the wall that you could attach hinges to.
I hope this gives you a springboard for some creative scribbling.
2011 Rockwood A128
60W solar system
Old 08-29-2011, 09:11 PM   #18
Solar
I purchased the solar panel from a company in Monreal Quebec, called Solar Power Canada. The kit I purchased came with 20 ft. 12 AWG cables, with the MC4 connectors and a 7 ft. set of separate cables and clamps that come off of the charge controller. - and ofcourse the panel itself and the charge controller.
We had just come back from Shenandoah National Park where i used the system for 7 full days. We had 5 full hours of sun each day and i was able to charge both batteries back up to 100 % each day. We ran the lights/sterio without any thought, along with the waterpump and fantastic cieling fan along with an Endless Breeze (fantastic fan) for the queen bed end.
Im thinking the maximum total draws for each night were about 20 amps, which the solar panel, which pumps out around 6 amps per hour in full sun easily replentished in about 4 hours.
Previous to this purchase we were using a 30 watt folding panel, which did the job quite well, however we were conserving power. We lasted 10 full days on a dual battery setup with the 30 watt panel at Acadia National Park ..last year.
will post pics tomorrow ... if i can figure out how too .. lol ..
D-mo
2011 Rockwood A122
Old 08-30-2011, 03:28 PM   #19
heres a pic of the dual battery setup on my camper ... the paint will be coming out tomorrow to touchup the cut edging ...
I'll start a separate thread tonight or tomorrow about the solar.
Cheers .. d-mo
2011 Rockwood A122
Old 08-30-2011, 08:20 PM   #20
Mostly Harmless
thehamguy1's Avatar
Great pic to show how you've adapted the tongue area for dual batteries. Some more questions popped up here...
What is the little grey box showing beneath the battery holder? Is it an isolator switch or do you even use one of those?
Second, our camper came with about a 400AH battery, so the most economical thing for us would be to get a second one of the same size--is that what you did? (I'm going by the recommendation that multiple battery systems should have all equivalent age and capacity batteries).
Finally, are your batteries parallel connected, or do you use just one at a time while charging the other?
2011 Rockwood A128
60W solar system
a128, homemade, modifications, screen door
