Old 09-24-2015, 09:06 AM   #1
chuck9997's Avatar
Hot Water Heater
I am unable to get to my a122s, right now. .. so maybe someone can answer. I bought this 2014 model a few weeks ago and have not even hooked up water to it yet. Not sure I will use the water heater or water system much. I bought this to simplify my camping. Really just wanted AC and off the ground camping. Anyway.. is the water heater, in the a122s, gas, electric, or both? Thanks.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 09-24-2015, 09:20 AM   #2
only gas , after the system is filled with water turn water pump switch on , then bleed air out . There is another switch to turn on the hot water heater which is self igniting after you turn on the gas supply ,it is very efficient and doesn't consume much after it heats up .We always fire it up as it is nice to wash your hands and face with hot water .
spellcast1 is offline   Reply With Quote
Old 09-24-2015, 09:23 AM   #3
if you use city water don't turn on the water pump ,
Old 09-24-2015, 09:47 AM   #4
TURBS's Avatar
Bleed air out of the system "ONLY" at the water heater pressure relief valve.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-24-2015, 10:06 AM   #5
DaveSchwartz's Avatar
Please explain. Why would the air care which hole it exits the top of the tank through?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-24-2015, 10:21 AM   #6
To be sure water is really in the tank and not on bypass
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 09-24-2015, 11:14 AM   #7
Not on bypass, sure but if I open the hot on a tap and have to wait while 6 gallons of air blow out, I'm already pretty sure of that even if I don't remember which way I last left the valves. Was just wondering at the "ONLY" injunction. I've actually done it both ways and there's never been a difference.
Old 09-24-2015, 11:33 AM   #8
Just makes sure the tank is full, but it really makes no difference whether you use the pressure relief valve at the tank or the hot water faucets. End result is the same.
Old 09-24-2015, 11:54 AM   #9
I think when I was picking up my 5er and the topic of winterizing came up, the tech was aghast that I used my pressure relief valve this way... said I'd weaken the spring over time and end up with drooling water heater syndrome. Even when the valve operates under normal conditions, the spring is deformed only the tiniest little bit, not like when you yank it open to the stop.
Old 09-24-2015, 11:58 AM   #10
Your tech was blowing smoke. You should have ask him if he knew the cycle life of the spring. I bet it is more than 52 cycles/year/10 yrs.
Old 09-24-2015, 11:59 AM   #11
TURBS's Avatar
I've done it for 10 plus years and not had one problem.
If you use a facet how do you know your tank is full?
Maybe you thought you un bypassed the wh? Maybe you forgot?
There's been at least two times on the forum where the person un bypassed his wh but the internal valve didn't turn just the handle.
TURBS
2011 32bhok Sabre
Old 09-24-2015, 12:04 PM   #12
TURBS
2011 32bhok Sabre
Had bypass valves for the last 9+ years on 4 trailers and never touched them. I do bleed the tank with the relief valve, but the faucets will do it also if the bypass valves are in the proper position.
Old 09-24-2015, 12:05 PM   #13
TURBS's Avatar
Only if!
TURBS
2011 32bhok Sabre
Old 09-24-2015, 12:18 PM   #14
chuck9997's Avatar
I'm the OP.. So the answer is gas. Thanks.
Old 09-24-2015, 12:40 PM   #15
Because the tank gurgles and the valve hisses for two minutes until water comes out?
Like many things in life, you gots to pay attention to what you're doing. Experience can be a hard teacher.
Old 09-24-2015, 12:43 PM   #16
I also prefer to stand on experience and not dogma.
I agree the pressure relief valve would be literally foolproof but its not the "ONLY" way.
Old 09-24-2015, 01:08 PM   #17
TURBS's Avatar
Fool proof way is to just use pressure relief valve.
TURBS
2011 32bhok Sabre
Old 09-24-2015, 01:26 PM   #18
wmtire's Avatar
Thanks chuck, for answering your own question. Sorry this thread got sideways and sidetracked..... and nobody was able to answer your initial question. So the A122s has a propane only water heater.
The site team has done a little cleanup on the off-topic stuff. The sidetracked things, we would like to leave, as they may help others in the future.
2011 Flagstaff 831 RLBSS
Old 09-24-2015, 01:42 PM   #19
chuck9997's Avatar
Thank you.. I don't mind the sidetrack stuff.. it's all good. And actually the 2nd poster on the thread (spellcast1) answered my question.
Old 09-24-2015, 01:46 PM   #20
wmtire's Avatar
Excellent, way to go Spellcast1.
heater, hot water, water, water heater
