Old 05-20-2014, 06:21 PM   #1
Hot water tank filling.
First camper. How do I fill my hot water tank after the campers water system has been drained. Do I fill my tank then turn on the pump?
Davech7 is offline   Reply With Quote
Old 05-20-2014, 06:34 PM   #2
Yes,
The easiest way is to put water in your fresh water holding tank.
Make sure the valves are all turned the correct way on your water tank and turn the pump on.
It will take a few minutes, but when your pump shuts off, the tank will be filled.
That is the way I have done it for years.
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
Old 05-20-2014, 06:51 PM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
Agree with markb5900... I like to connect to city water pressure and purge all the air from both cold and hot, shower, toilet, and all sinks. Then fill the fresh water tank. shut the city water pressure off and listen for the pump to start. If not started (make sure it is turned on. lol..) then run the sink water and listen again. Make sure it stops pumping when the water is turned off. Then turn on the water heater.
donanddona is offline   Reply With Quote
Old 05-20-2014, 09:19 PM   #4
Thanks for the help!!
Davech is offline   Reply With Quote
Old 05-20-2014, 09:44 PM   #5
To double check that your hot water tank is full, bleed the hot water blow off valve until water piddles out. Then its full.
Old 05-23-2014, 05:15 AM   #6
I just bought the a122s and it's my first camper. Can anybody tell me how to raise the water heater temp. I looked through the manuals but don't see anything
s2111 is offline   Reply With Quote
Old 05-23-2014, 05:36 AM   #7
Witch Doctor's Avatar
The temp is set by the limit control. Only way to raise the temp is to buy a higher temp limit switch. How it works is the limit reaches it set temp and open and shuts the electric or burner off. It's non adjustable. They do sell higher temp limit switches at RV stores. You would need two (1) electric and (1) 12 volt side. EBAY has 2 130 degree and 140 degree, for $25.95 each
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-23-2014, 05:39 AM   #8
Thank you for the speedy response
Old 05-25-2014, 09:09 PM   #9
Mostly Harmless
thehamguy1's Avatar
You won't need the electric temp limit switch for your A-frame, just the 12v one; it has a gas-only water heater, not a gas/electric one.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 05-25-2014, 09:20 PM   #10
Herk7769's Avatar
I agree with Don. Filling the hot water heater is last on my de-winterizing checklist. I always sanitize my fresh water lines; then fill the hot water tank from the sanitized fresh water tank using the on board pump.
Wait 24 hours and drain the system completely. Refill and go camping.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
hot water, tank, water, water tank
