Old 06-21-2016, 07:13 AM   #11
Ford Idaho's Avatar
Originally Posted by Pooneil View Post
The cover on my lug nut slipped while I was changing the tire at a gas station due to a defect in the tire. I used a hammer to drive the socket on the nut so I could remove it. Then I destroyed a screwdriver using it to punch the nut out of the socket.
Why do we have 12 point sockets anyway when all the nuts (lug and otherwise) I've seen are 6 sided?
The Harbor Freight torque wrench is certainly not a professional tool, but it works very well for this purpose at a price that lets me keep it in my camper at all times. I don't even want to think about what a Snap On wrench would cost. It's the right tool for the job.
Yep, the wrench is for the lite only, I never remove it when at home.
Ford Idaho is online now   Reply With Quote
Old 06-21-2016, 07:23 AM   #12
Originally Posted by Cut_un View Post
How often do you guys check the lugs?? Mine says 100 ft lbs each time out...
I think that's overkill. If the wheels have been off I check at the start of the trip, when we arrive and before the start of the next trip. In ten years of camper ownership I have not found a single loose lug nut.
I do still check periodically, though.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 06-21-2016, 07:37 AM   #13
Brother Les's Avatar
This is another thing to add to your tool box that stays with the camper in order to get your lugs off when needed.
Brother Les
Old 06-21-2016, 08:10 AM   #14
Dazed & Confused
M&K Hoffman's Avatar
Originally Posted by Russ in CO View Post
Hey all!
I can't get an old style 4-way on to these lug nuts. There isn't enough clearance around the wheel.
What are you using?
Thank you,
I HATE those *%@# stickers on the wheels!
BTW Torque wrench, extension and 6 point socket.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 06-21-2016, 08:24 AM   #15
Engineer of Crazy Train
ChooChooMan74's Avatar
I have in the truck, a breaker bar, a short extension, a harbor freight torque wrench, and the 6 sided impact sockets for both the truck and trailer, and the lug lock tool for the truck.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 06-21-2016, 08:33 AM   #16
B and B's Avatar
I have not checked mine in 2 years. Maybe time again to do so. Once seated they do not loosen.
I use 1946 vintage Craftsman deep socket set to check with a standard Torque Wrench. They are 12 point as well. My father used these as a tradesman for 50 years and now i have had them since 1983. Like new!
You get what you pay for in tools.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 06-21-2016, 08:50 AM   #17
If you have had them off for any reason, after a hundred miles. Supposed to do that on your vehicle too, but tire shops rarely tell you that.
tjm is online now   Reply With Quote
Old 06-21-2016, 08:53 AM   #18
SeaDog's Avatar
I think its important to check the torque on initial install of the wheel and after about the first 100 miles after that only after a wheel has been removed. this has worked for me. I use a 1/2" torque wrench and 6" extension and either 12 point or 6 which ever is handy.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 06-21-2016, 09:51 AM   #19
I torque periodically rather than each trip as I've never had them loosen up after changing a tire and then re-torquing. Just when I am doing other work around the camper.
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-21-2016, 10:56 AM   #20
As I understand one reason is for positioning in tight spaces. Ever try to get a 6 point socket on a nut if you only have 3-4 inches of space to ratchet in? Sometimes you can, sometimes you need a 12 point. Best to have a set of both 6 and 12 point sockets. I use 6 point for high torque situations which is what I should have done with camper lug nuts and I wouldn't have had the problem I did. I got lazy and used the 12 point because it was handy and paid the price!
2012 Rockwood a124
mzak is offline   Reply With Quote
