Old 06-22-2016, 11:39 AM   #41
Originally Posted by Boots49 View Post
I also check the tires for wear & a general walk around checking high as well as low.
I do this also. A walk around at every stop looking at tires and the hitch. It almost always just confirms that everything is OK, but I once found a bulge in the sidewall of a tire that would have shortly led to a blowout on the highway.
I have also discovered a forgotten roof latch or similar minor problems that should have been caught when closing up and hitching. But everyone makes mistakes so its best just allow for the possibility and recheck when you stop.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-22-2016, 02:25 PM   #42
djemgoss's Avatar
I use a torque wrench with 19mm, 6 point, deep socket!
Dave & Elaine
Brookfield, WI
2016 Rockwood, ROO 21SS, pulled by a 2015 F150 XT, Super Cab, 2.7L Eco Boost, with 3.55 axle. Electric 6-speed auto trans w/tow mod. Tow package & integrated trailer brake. 7,600 lb. tow capacity. 145 wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 06-22-2016, 03:20 PM   #43
BamaBob's Avatar
Originally Posted by Russ in CO View Post
Hey all!
I can't get an old style 4-way on to these lug nuts. There isn't enough clearance around the wheel.
What are you using?
Thank you,
Russ
Russ,
Harbor freight and like the others have said a torque wrench with a extension is your friend.
Originally Posted by jgourlie View Post
I haven't been checking mine...hmmmm...maybe time that I do
YEP! You should check the torque on your trailer wheels at least every other day when driving. Before you leave when camping (unless checked when you arrived.)
Easy procedure: set the torque wrench and go around the rig - shouldn't take more than 5-10 min.
And you DO have a TPMS?
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-22-2016, 08:24 PM   #44
B and B's Avatar
How are you checking/tightening your lug nuts?
Originally Posted by mike.t View Post
Do you (OP) do the same on your TV?/family car? Daily driver? When you take your car in for service is checking/tightening lug nuts on their to do list? You'll ruin your camping fun worrying about stuff like this.
Agreed. I never have checked a wheel on any car or truck in owned.
I don't have TMPS
I do check tires and hubs for heat at every stop
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-22-2016, 08:45 PM   #45
mike.t's Avatar
Originally Posted by BamaBob View Post
Russ,
Do you check your TV the same? Wife's car? Daily driver?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 06-22-2016, 08:50 PM   #46
Dr-G's Avatar
Originally Posted by Tom48 View Post
Ditto. Usable torque wrench can be had on sale or with coupon at HF for about 20 bucks. Set torque on wrench tighten til click. Once in a while I back the torque off to nearly loose and re-torque
Oh, and I take the torque off the wrench back to zero before I put the wrench in it's case and put it away.
Yes, this ^^^
Also don't use the torque wrench to remove the lugnuts, use a breaker bar.
I use Harbor Freight all the time for these purposes.
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Days Camped '16 - 12
Days Camped '17 - 0
Dr-G is offline   Reply With Quote
Old 06-22-2016, 09:48 PM   #47
Kinda what I was thinkin too!
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 06-22-2016, 10:21 PM   #48
Russ in CO's Avatar
Hi Mike
OP here!
No, I don't typically check the lug nuts on my other vehicles. We just bought this A-frame, last month, and already drove it over 1000 miles.
Around the wheel wells, and inside the unit it advises checking the lug nuts for tightness. Not one to have a wheel come off while going down the road, I'd thought I would put a 4 way lug wrench on it to check. It didn't fit...so I thought I would ask here. A lot of the hardware, and build quality seems a little less than I am used to. Also, This is my first RV type vehicle.
Be safe going down the road,
Russ
Thanks to all for the responses.
2016 Flagstaff T-12BH A-frame camper
Livin' the dream!
Russ in CO is offline   Reply With Quote
Old 06-22-2016, 11:08 PM   #49
Happy camping, Russ.
Tom
2012 Rockwood A122S
Old 06-22-2016, 11:15 PM   #50
Russ in CO's Avatar
Thanks Tom,
We just returned from a 2 nighter. About 40 miles west of here. 9800 ft altitude!
Livin' the dream!
