06-20-2016, 12:35 PM
How are you checking/tightening your lug nuts?
Hey all!
I can't get an old style 4-way on to these lug nuts. There isn't enough clearance around the wheel.
What are you using?
Thank you,
Russ
2016 Flagstaff T-12BH A-frame camper
Livin' the dream!
06-20-2016, 02:07 PM
Torque wrench with extension and socket.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
06-20-2016, 02:11 PM
I have similar wheels and use a thin-walled 19mm deep socket with a 1/2" drive torque wrench.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
06-20-2016, 02:59 PM
+1
I switched to a 6 point socket from a 12 point after one of the chrome covers on the lug nuts slipped. A standard wall thickness socket works on my wheels.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
06-20-2016, 03:04 PM
I go RV'ing not Camping
I haven't been checking mine...hmmmm...maybe time that I do
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
06-20-2016, 10:35 PM
Originally Posted by Pooneil
+1
Same here! Had to destroy cover so I could remove nut and then wheel.
2012 Rockwood a124
06-20-2016, 10:53 PM
Plus one for the thin wall 17mm, Harbor Freight brand.
Harbor Freight type torque wrench as well.
06-21-2016, 06:39 AM
The cover on my lug nut slipped while I was changing the tire at a gas station due to a defect in the tire. I used a hammer to drive the socket on the nut so I could remove it. Then I destroyed a screwdriver using it to punch the nut out of the socket.
Why do we have 12 point sockets anyway when all the nuts (lug and otherwise) I've seen are 6 sided?
The Harbor Freight torque wrench is certainly not a professional tool, but it works very well for this purpose at a price that lets me keep it in my camper at all times. I don't even want to think about what a Snap On wrench would cost. It's the right tool for the job.
Tom
2012 Rockwood A122S
06-21-2016, 06:44 AM
How often do you guys check the lugs?? Mine says 100 ft lbs each time out...
06-21-2016, 06:52 AM
Although a little pricy, I have a set-up I love.
I bought a DeWalt cordless impact wrench. It has a rating around 300 ft./lbs.. I also ordered through Amazon a set of torque sticks. Every time I need to check the lugs, I pop the 100 ft./lb. stick on there and go around like a NASCAR pit stop. Quick, easy, and from what I can tell, about as accurate as most torque wrenches.
I try to check them at the start of each trip.
06-21-2016, 07:13 AM
Yep, the wrench is for the lite only, I never remove it when at home.
06-21-2016, 07:23 AM
I think that's overkill. If the wheels have been off I check at the start of the trip, when we arrive and before the start of the next trip. In ten years of camper ownership I have not found a single loose lug nut.
I do still check periodically, though.
06-21-2016, 07:37 AM
This is another thing to add to your tool box that stays with the camper in order to get your lugs off when needed.
Brother Les
06-21-2016, 08:10 AM
Dazed & Confused
Originally Posted by Russ in CO
Hey all!
What are you using?
Thank you,
Russ
I HATE those *%@# stickers on the wheels!
BTW Torque wrench, extension and 6 point socket.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
06-21-2016, 08:24 AM
Engineer of Crazy Train
I have in the truck, a breaker bar, a short extension, a harbor freight torque wrench, and the 6 sided impact sockets for both the truck and trailer, and the lug lock tool for the truck.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
06-21-2016, 08:33 AM
I have not checked mine in 2 years. Maybe time again to do so. Once seated they do not loosen.
I use 1946 vintage Craftsman deep socket set to check with a standard Torque Wrench. They are 12 point as well. My father used these as a tradesman for 50 years and now i have had them since 1983. Like new!
You get what you pay for in tools.
B and B
06-21-2016, 08:50 AM
If you have had them off for any reason, after a hundred miles. Supposed to do that on your vehicle too, but tire shops rarely tell you that.
06-21-2016, 08:53 AM
I think its important to check the torque on initial install of the wheel and after about the first 100 miles after that only after a wheel has been removed. this has worked for me. I use a 1/2" torque wrench and 6" extension and either 12 point or 6 which ever is handy.
Retired Navy
2016 Flagstaff 26 FKWS
06-21-2016, 09:51 AM
I torque periodically rather than each trip as I've never had them loosen up after changing a tire and then re-torquing. Just when I am doing other work around the camper.
Tom
2012 Rockwood A122S
06-21-2016, 10:56 AM
[QUOTE=Pooneil;1233837]
As I understand one reason is for positioning in tight spaces. Ever try to get a 6 point socket on a nut if you only have 3-4 inches of space to ratchet in? Sometimes you can, sometimes you need a 12 point. Best to have a set of both 6 and 12 point sockets. I use 6 point for high torque situations which is what I should have done with camper lug nuts and I wouldn't have had the problem I did. I got lazy and used the 12 point because it was handy and paid the price!
2012 Rockwood a124
