Old 10-09-2012, 07:13 PM   #1
How to handle the Ant invasion?
Today I pulled the A-frame into driveway from carport, opened it first time since April to prep for a trip to SC at end of month and again I find black ants, some dead from the traps I placed in April and others quite active in each corner. I put down Boric acid powder for now as they hate that stuff, but considering using clear caulk around as much of the inside floor area as possible especially at the end storage areas. Has anyone else got a better idea?
Anne
DobeFanatic is offline   Reply With Quote
Old 10-09-2012, 07:32 PM   #2
Crusader's Avatar
Find black ant hills outside and pour diatomaceous earth inside the ant hills and all around them. Diatomaceous earth is a fine powder that comes from the earth and is safe for humans and animals, but effectively kills ants. Sprinkle diatomaceous earth around the outsides of the carport and the concrete cracks of the carport
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 10-09-2012, 07:40 PM   #3
AquaMan's Avatar
I didn't know this was a deterant for ants, but it's also a filtering element for swimming pools. We had an ant invasion last year when in FL for spring break, and now we treat all areas where the camper touches the ground with a repellant. Seems to work, but may try the "DE" (diatomaceous earth) approach.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-09-2012, 07:52 PM   #4
Jeep4Two's Avatar
DE is just fine diatom skeletons. They are razor sharp and cut up the bodies of many insects. So it's not a deterrent as much as a pesticide, so to speak.
They crawl through it, it cuts up their bodies and they die from dehydration.
Works great for lots of pests, but its not totally safe to handle. Use gloves and wash up. It can irritate the skin. Avoid breathing any dust as well.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 10-09-2012, 08:03 PM   #5
I see Lowe's has it: most of the reviews reported very effective on bedbugs (interesting) and also a few using it for ants/fleas, so will try it. Says it is very irritating to skin and eyes- to use gloves/mask, and almost like a talc powder composition. Thanks, Anne
Old 10-09-2012, 08:15 PM   #6
Jeep4Two's Avatar
That's the stuff. Works great on slugs too.
Jeep4Two
Old 10-10-2012, 04:37 PM   #7
thumbs up
This is the way to go. I would not try to seal cracks against ants because you can never seal up all of the possible entry points. But Diatomaceous earth will stop them from getting in, and there is no harmful chemical to worry about.
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 10-10-2012, 06:14 PM   #8
djmac1964's Avatar
Whatever you do, good luck! We had a Jayco Hybrid, that apparently had a small roof leak over the bathroom, which caused some water damage to the ceiling and walls in the bathroom. The carpenter (black) ants found the moist wood, and completely destroyed the ceiling in the bathroom! We could actually hear them up there munching, and the ceiling was very soft. When I finally cut a portion of the vinyl ceiling out, I had hundreds of ants and larvae fall out on me, it was a really nasty scene! They had managed to make a colony in our ceiling, and it was a real pain to gt rid of them, and repair the ceiling!
Don
2013 XLR 27HFS Toy Hauler
2014 Silverado 2500HD Z71 Crew Cab
99 Club Car Golf Cart
djmac1964 is offline   Reply With Quote
