If you notice, other than the top cover, the compartment is integral to the sides of the camper. Now if you’re only interested in removing the tray from the lower compartment, that is completely doable. Just tape up the restraining hook and slide it out. Finally, it is entirely possible (but I’m not sure because I haven’t looked closely) that the plywood shelf & its support in the upper portion of that compartment could be removed, making the compartment accessible from the top. If there are no screws holding the tray you will probably have to cut it out, maybe by using a small rotary cutter (Dremel style, but perhaps more robust).
2019 Puma 255RKS 5th Wheel
2013 Ford F-150 w/ max tow
