Old 01-18-2016, 06:17 PM   #1
Daybreaker's Avatar
How To Remove Tail Light Plate?
I recently bought a 2012 Forest River T12DD and the left signal bulb is burned out. I need to replace it, but I'm having a difficult time trying to remove the face plate. I see there are two white clips on both side that are holding it. I used a flat screwdriver to see if I can push this clip in, but it's pretty hard and I'm afraid to push it any further to avoid breaking it. Any idea on how to remove this face plate?
I have attached a picture of the light I'm referring to.
Many thanks!
Daybreaker is offline   Reply With Quote
Old 01-18-2016, 09:16 PM   #2
Left Coast
Rubber gasket is holding it....while depress'n clip, gently pry the lense off
Old 01-18-2016, 09:25 PM   #3
Daybreaker's Avatar
Thank you Bob!
Old 01-18-2016, 09:43 PM   #4
B47
Might put a little lube on the gasket before reinstalling the lens - make removal easier next time.
light
