Old 09-16-2015, 12:34 PM   #11
Originally Posted by Timex View Post
On mine:
A-Living Room
B- Bedroom
C- External
Same with mine.
VMI'62
Edmund is offline   Reply With Quote
Old 09-16-2015, 01:05 PM   #12
I have the same Kenwood car type radio in my A Frame. The outside speaker is either controlled by the fader or balance control. My radio was wired wrong, where the balance controlled inside vs. outside and the fader controlled left and right. I switched the wires and all is well.
If I put my fader all the way to rear the outside speaker is only on; if I put the fader to front the two inside speakers are only on; or I can put it in between to run all speakers.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 09-16-2015, 07:27 PM   #13
Fluffywhitedogs's Avatar
X3, try the fader . I upgraded to this exact stereo. I simply copied the way the original one was wired, and the fade function is how I switch the sound from outside to inside with both the old and new stereo...
Originally Posted by asquared View Post
As others suggested. Fade usually will control inside outside instead of front/back
Fluffywhitedogs is offline   Reply With Quote
Old 09-20-2015, 10:57 AM   #14
PegKen's Avatar
TrishB,
I have paperwork for Kenwood KDC-152 which is installed in my Rockwood A122S. It reads:
"You can switch from inside speakers to outside speakers by accessing the stereo FUNCTION mode entered by pressing the volume knob. Press the volume knob again to select SETTINGS. Next, turn the volume knob to select BALANCE in the menu.
>BALANCE - Switches from inside speakers to outside speakers.
>FADER - Switches from front to rear inside speakers.
For complete instruction on how to access Balance and Fader Functions, refer to page #10 of the radio's owners manual."
I hope this helps and is correct info. Note: I have not had the opportunity to verify this info as my A122S is currently in the shop getting a roof actuator installed.
Cheers!
PegKen
PegKen is offline   Reply With Quote
Old 09-20-2015, 09:55 PM   #15
Balance is supposed to control stereo sound between two different sound tracks, left and right. Otherwise you are getting monotone rather than stereo, and you are only geting one sound track.
Fader is supposed to control front to rear for both tracks. The wiring above does not allow stereo sound in side the trailer, but puts the left track outside and the right track inside.
2015 Rockwood A128S
2010 Rockwood 2604
Old 09-20-2015, 11:29 PM   #16
Have the same radio in my 2514G. It is wired horribly........you will have to go into the menus and find the balance control. The right channel is outside and the left channel is inside. The fade control adjusts between the 2 inside speakers. Why it was done this way is anybody's guess. You don't even have stereo inside the coach! I have been going to pull it out and rewire (very easy) so I have stereo inside and can use the fade control to go from inside/outside. There is only 1 speaker outside so you can only have 1 channel. So easy to have done it right at the factory.....lol
61cubby is offline   Reply With Quote
Old 09-21-2015, 11:21 AM   #17
Sorry I'm slow getting back to thank folks for the responses, but we've been camping in the Canadian Rockies with spotty Internet.
I think that fader or balance are the way to go, but haven't figured out how to do that. I can find the fader and balance settings, but the choices are bizarre and don't show what the instructions do. I'm usually pretty good with electronics, but NOTHING on this radio is intuitive and the directions are a mystery.
Anyway, thanks for pointing me in the right direction and I'll keep plugging away at it as my sanity allows.
Trish
TrishB is offline   Reply With Quote
Old 09-21-2015, 11:43 AM   #18
On mine:
A-Living Room
B- Bedroom
C- External
Same on our 12Flagstaff 8528RKWS
Old 09-21-2015, 12:07 PM   #19
nomad297's Avatar
X 2
Bruce
Old 09-21-2015, 12:40 PM   #20
DaveSchwartz's Avatar
[PetPeeveMode]
I'm sometimes as guilty as anyone about spouting off without facts or information but when the OP gives the exact model number of the equipment they're having a problem with, come on - do a little research. Google is your friend.
[/PetPeeveMode]
Those who suggested the 'fade' function excepted.
Ducking now...
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
