Old 09-21-2015, 02:29 PM   #21
Originally Posted by DaveSchwartz View Post
[PetPeeveMode]
I'm sometimes as guilty as anyone about spouting off without facts or information but when the OP gives the exact model number of the equipment they're having a problem with, come on - do a little research. Google is your friend.
[/PetPeeveMode]
Those who suggested the 'fade' function excepted.
Ducking now...
Iwritecode is offline   Reply With Quote
Old 09-30-2015, 09:46 PM   #22
gpa
I have a Kenwood in my t12rb and had to adjust the balance to turn off the outside speaker.
gpa is offline   Reply With Quote
Old 10-08-2015, 04:11 PM   #23
We're home now and had a great trip. Again, thanks to all who answered. We both spent far too much time trying to figure out the stereo. We found Balance and Fader Controls, but they were weird and didn't seem to do what we needed. (We could scarcely figure out how to get the AM/FM on and tuned.) Finally we just said "screw it" and we used my iPhone and our solar powered Bluetooth Roku portable speaker. All we really care about is a couple of NPR programs anyway. We didn't spend that much time in the trailer.
Maybe we'll swap this weird radio out for something more intuitive.
TrishB is offline   Reply With Quote
Old 04-02-2016, 09:39 AM   #24
member
big vic is correct. it's reasonable to expect stereo operation (i.e. both left AND right channels) both inside and outside the trailer. anything else is a workmanship flaw, correction of which should be covered under warranty.
robhagen is offline   Reply With Quote
Old 04-03-2016, 07:03 PM   #25
Originally Posted by Big Vic View Post
I have the same Kenwood car type radio in my A Frame. The outside speaker is either controlled by the fader or balance control. My radio was wired wrong, where the balance controlled inside vs. outside and the fader controlled left and right. I switched the wires and all is well.
If I put my fader all the way to rear the outside speaker is only on; if I put the fader to front the two inside speakers are only on; or I can put it in between to run all speakers.
I thought mine was wired wrong too but apparently Forest River thinks using the balance to switch from inside to outside speakers and listening to only left or right track on the 2 inside speakers is ok. They even included an addendum saying so. Anyway.. Big Vic, how did you rewire the speakers? I'm thinking easiest way is to pull the radio out of the cabinet? lol I keep thinking... this thing is still brand new... do no harm, do no harm...
timfuji is offline   Reply With Quote
Old 04-04-2016, 05:43 PM   #26
Kind of difficult to achieve proper stereo operation with a single speaker.
All the Forest River A-frames I've seen (the newer bigger models may be different) only have 1 outside speaker. And I haven't seen a car stereo in decades that has a mono/stereo switch to combine the channels. I seem to remember back in the '80s that some car stereos had an automatic switch to mono when the FM signal was weak, and I think I had one that had a manual toggle switch on the front panel. So right from the start, you have a problem making the outside speaker work correctly. You would have to connect the outside speaker to both left and right rear speaker connections to get both channels.
Add to that the crappy job of installing stuff done by Forest River, and I'm not surprised when the speakers get hooked up wrong to the stereo. The fix to put the outside speaker as the rear car speaker, and the inside speaker as left and right front speakers is not difficult, but does involve removing the microwave for access to the back of the radio.
One of these years, I may replace the standard Kenwood car stereo with one that has a USB input, or at least a headphone jack input to have my phone as a source. But since SWMBO doesn't appreciate my taste in music, there's no hurry.
Fred W
2014 Rockwood A122 A-frame
3 weeks to the Utah 5 trip!
camping Colorado and adjacent states one weekend (or one week in this case) at a time
Old 04-04-2016, 05:55 PM   #27
Butch Wilson's Avatar
The radio on my 2016 t21qbhw has a usb input as well as a aux input. You are correct 1 outdoor speaker with right and left channels combined. FR must have upgraded !
Butch Wilson is offline   Reply With Quote
Old 04-06-2016, 03:56 AM   #28
I just rewired mine (2016 212HW) today before work. Wasnt in my driveway 24 hours... I set it up so the front is inside, and the rear is outside. I googled the schematic online, then used the fader/balance to figure out what was wired where, and worked accordingly. only took a few min. Off the top of my head I swapped the green circuit and the grey circuit. Stereo sounds MUCH better now. Wish it had 2 outside speakers for stereo on both ends, but thats a modification I can do later.
Luv70sFords is offline   Reply With Quote
Old 04-07-2016, 10:25 AM   #29
I added a second outside speaker (waterproof) that had the appearance and same specs as original. They sit about 5 ft apart, so there is some stereo separation audible.
The Kenwood radio came with a manual that showed the schematic for connecting two sets of rear speakers and two sets of front speakers. The manual is probably available online with a Google search. Once I removed the radio from the cabinet, it was easy to find the color coded speaker wires and re-connect them as I wished to the speaker wires.
As discussed above, IMHO the proper install allows the fader to variably adjust stereo sound to rear (outside) or front (inside) speakers and still maintain the balance feature to adjust right and left stereo channels.
If you only want to use one outside speaker, you will lose stereo sound outside because you are only running it on one channel (left or right).
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is online now   Reply With Quote
Old 04-07-2016, 02:20 PM   #30
Retread Popup Owner
Wojo's Avatar
We must have gotten lucky with our 2014 T12DDST. The speakers are all controlled with A, B, and C buttons on both the radio and on the remote. Each speaker can be turned on and off independently of the others. The outside speaker has both left and right wired into it.
2014 Flagstaff T12DDST A Frame
2015 Nissan Xterra
2015 Nissan Frontier
Camping Photos
Camper Mods
Wojo is offline   Reply With Quote
