09-15-2015, 12:36 PM
How to turn off external speaker?
We have a Kenwood KDC-152 radio. Sales person said the speaker could be deactivated. Asked a tech guy at Camping World and he said dismissively to read our instructions - that there was a setting for it. Well, if there is, I can't find it.
It feels like being a bad neighbor to make neighbors listen to whatever we do - especially since we're inside with the door closed! We're ready to pull the speaker and snip a wire - except that it might be useful at some point. Any ideas?
Thanks!
Trish
(2015 FR 12' Hard Side)
09-15-2015, 12:38 PM
You probably have A,B and C bottoms on the front facing of the radio. Depress them until you figure what speakers they control.
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
09-15-2015, 01:58 PM
Try the left/right balance. One of them turns off the outside speaker.
ThePoms
Rockwood
2016 A212HW
09-15-2015, 05:28 PM
The A and B buttons control the speakers.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
09-15-2015, 08:40 PM
On my camper (a) button internal speaker on cabinet. (B) button controls the bass boom box. (C) button outside speakers
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
09-15-2015, 08:49 PM
On mine:
A-Living Room
B- Bedroom
C- External
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
09-15-2015, 08:52 PM
This is his radio
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
09-15-2015, 08:54 PM
Oh, I don't know about that one.
I'm out.
09-15-2015, 10:07 PM
I don't have that radio, but if there aren't A,B,C buttons on it, I would try the "Fade" function. I once had a trailer with a Jensen stereo in it ---- you could "Fade" to the outside or inside or mix the two.
09-15-2015, 10:26 PM
As others suggested. Fade usually will control inside outside instead of front/back
2014 Sabre 34REQS-6
09-16-2015, 11:34 AM
Originally Posted by Timex
On mine:
A-Living Room
B- Bedroom
C- External
Same with mine.
VMI'62
09-16-2015, 12:05 PM
I have the same Kenwood car type radio in my A Frame. The outside speaker is either controlled by the fader or balance control. My radio was wired wrong, where the balance controlled inside vs. outside and the fader controlled left and right. I switched the wires and all is well.
If I put my fader all the way to rear the outside speaker is only on; if I put the fader to front the two inside speakers are only on; or I can put it in between to run all speakers.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
09-16-2015, 06:27 PM
X3, try the fader . I upgraded to this exact stereo. I simply copied the way the original one was wired, and the fade function is how I switch the sound from outside to inside with both the old and new stereo...
09-20-2015, 09:57 AM
TrishB,
I have paperwork for Kenwood KDC-152 which is installed in my Rockwood A122S. It reads:
"You can switch from inside speakers to outside speakers by accessing the stereo FUNCTION mode entered by pressing the volume knob. Press the volume knob again to select SETTINGS. Next, turn the volume knob to select BALANCE in the menu.
>BALANCE - Switches from inside speakers to outside speakers.
>FADER - Switches from front to rear inside speakers.
For complete instruction on how to access Balance and Fader Functions, refer to page #10 of the radio's owners manual."
I hope this helps and is correct info. Note: I have not had the opportunity to verify this info as my A122S is currently in the shop getting a roof actuator installed.
Cheers!
PegKen
09-20-2015, 08:55 PM
Balance is supposed to control stereo sound between two different sound tracks, left and right. Otherwise you are getting monotone rather than stereo, and you are only geting one sound track.
Fader is supposed to control front to rear for both tracks. The wiring above does not allow stereo sound in side the trailer, but puts the left track outside and the right track inside.
2015 Rockwood A128S
2010 Rockwood 2604
09-20-2015, 10:29 PM
Have the same radio in my 2514G. It is wired horribly........you will have to go into the menus and find the balance control. The right channel is outside and the left channel is inside. The fade control adjusts between the 2 inside speakers. Why it was done this way is anybody's guess. You don't even have stereo inside the coach! I have been going to pull it out and rewire (very easy) so I have stereo inside and can use the fade control to go from inside/outside. There is only 1 speaker outside so you can only have 1 channel. So easy to have done it right at the factory.....lol
09-21-2015, 10:21 AM
Sorry I'm slow getting back to thank folks for the responses, but we've been camping in the Canadian Rockies with spotty Internet.
I think that fader or balance are the way to go, but haven't figured out how to do that. I can find the fader and balance settings, but the choices are bizarre and don't show what the instructions do. I'm usually pretty good with electronics, but NOTHING on this radio is intuitive and the directions are a mystery.
Anyway, thanks for pointing me in the right direction and I'll keep plugging away at it as my sanity allows.
Trish
09-21-2015, 10:43 AM
On mine:
A-Living Room
B- Bedroom
C- External
Same on our 12Flagstaff 8528RKWS
09-21-2015, 11:07 AM
X 2
Bruce
09-21-2015, 11:40 AM
[PetPeeveMode]
I'm sometimes as guilty as anyone about spouting off without facts or information but when the OP gives the exact model number of the equipment they're having a problem with, come on - do a little research. Google is your friend.
[/PetPeeveMode]
Those who suggested the 'fade' function excepted.
Ducking now...
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
