Old 07-24-2015, 06:38 AM   #1
I Ask Out of Ignorance?
I know there have been many discussions on what type of tires to get for our Aframes.
But a questions suddenly popped into my mind...and I'm strictly talking about our Aframes not regular travel trailers or 5th wheels.
Our Aframes fully loaded don't weigh anymore than what a car or truck would weigh so why couldn't you use regular car/truck tires on our Aframes? Would the size of the rims be the answer?
David
Tow Vehicle: 2012 Durango 3.6 Pentastar Engine
Total nights camping 2014-(10)
Total Nights Camping 2015-(9)
Total Nights Camping 2016-(5)
Total Nights Camping 2017-(4)
Total Nights Camping 2018-(7)
mlsa3 is offline   Reply With Quote
Old 07-24-2015, 06:49 AM   #2
TURBS's Avatar
Tire weight rating would be a huge consideration.
Find a passenger car tire of the same size and see what the weight rating is compared to you st tire.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
Old 07-24-2015, 06:55 AM   #3
Herk7769's Avatar
Backing a trailer involves making the tire do things no car tire needs to see (like twisting); it needs to be able to sit for 11 months yet spin up to 65MPH without warm up (and not fail!); it supports your camper without shocks yet is resistant to cupping from bouncing down the highway; it needs to support loads far in excess of a similar size car tire...
I could go on, but why bother?
HAM CALLSIGN - KC3FFW
Old 07-24-2015, 07:21 AM   #4
A-Frames are single axle so they don't see (Twisting/layover) side loads like (Dual or Triple Axel) units! Youroo!! Check the Load Specs you might find a tire that will work?
Old 07-24-2015, 11:17 AM   #5
The stock Westlake ST tires on my A122 are 185R-13" Load Range D. I don't think I'm going to find any 13" car tires with a 1710 lb load rating - which is about 10% cushion over max GVWR. And I don't know of any LT 13" tires.
Also, I have not found that size ST tire in any brand besides Westlake (which have done have just fine for the first 3,000 miles). Given the lack of problems, I don't see any point in up-sizing my wheels (including spare) to get supposedly better tires.
Fred W
2014 Rockwood A122
2008 Hyundai Entourage (minivan)
Old 07-24-2015, 12:18 PM   #6
rsdata's Avatar
being ignorant of trailer tire ins and outs for the first 30 years of my towing life, I always used passenger tires on my boat trailer (about 2,000 total pounds) and regularly towed it thousands of miles each year without any problems, blowouts, tire cupping or anything noticeable happening. I had 3 tire pairs over this time period, all but the first pair were Goodyear passenger car tires, 14" size. Last year I got my 4th set. I replaced the rims and tires with ST tires, only because I needed new rims and the mounted tires I got had ST rated tires already installed.
now that I have a tandem axle HTT, I better realize the stresses and added weight (4,600#) that I have on my trailer and I figure that ST tires of the proper size and inflation are the best that I can do
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 07-24-2015, 04:43 PM   #7
Cathcartww's Avatar
If you have 13" wheels, you are pretty limited to ST tires - I don't think you will find many 13" truck or passenger tires with that kind of load range. If you have 14" wheels, the Kumho Radial 857, an "all position" tire, has good capacity ratings and is very well liked by the single axle crowd - Casitas, etc.
Cathcartww is offline   Reply With Quote
Old 07-24-2015, 08:29 PM   #8
Dabmeb's Avatar
You need to consider highway safety codes as well. There are lots of places that will not allow a trailer on the road with P or LT rated tires. Lots of tire shops also will not install them on trailers for liability concerns
Dabmeb is offline   Reply With Quote
Old 07-25-2015, 03:06 AM   #9
Where are these (Places) that check your (P or LT rated Tires)? Are they in the USA? Youroo!!
Old 07-25-2015, 12:38 PM   #10
I run LT tires on my flatbed trailer. I see nothing special about ST tires. You can get LT tires at a higher weight rating per size then ST tires. As far as stresses I don't see anymore twisting of a trailer tires then if you sat in your vehicle and turned your front tires full left to right while not moving. I have never heard of anyone checking what type of tires were on a trailer.
Loranimal is offline   Reply With Quote
