Old 08-30-2015, 06:08 PM   #1
chuck9997's Avatar
I see the light!
Just bought a 2014 A122s.. looking up.. I noticed a little bit of daylight at the apex on the door side. I haven't climbed up to take a close look. Not sure if it's coming from the top or light getting in from the side and just reflecting on the inside top. How well do the rockwood aframes seal at the top? Next time I set it up I will try and push hard on the door side wall and see if it seals better.
Any similar experiences?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 08-30-2015, 06:16 PM   #2
That is a common occurrence. Some people have put some sticky back foam from a local home center store. I've not done this but probably should.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-30-2015, 06:50 PM   #3
chuck9997's Avatar
So.. I am assuming it's coming from under the roof overlap.. and would not cause a leaking problem.. unless it's a windy to rental rainfall.
Old 08-30-2015, 06:52 PM   #4
chuck9997's Avatar
Torrential rainfall.. not to rent.
Old 08-30-2015, 10:50 PM   #5
not an issue with rain but you'll want to get some ac window foam to pack in there to keep the mosquitoes out. One strip of the 2" cut in half is enough for both side walls at the peak.
2015 A122S
CJofWolfcreek is offline   Reply With Quote
Old 09-01-2015, 05:59 PM   #6
mudman2's Avatar
Cotton balls keep the skeeters out. No problem here with water leak.
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 09-01-2015, 06:16 PM   #7
chuck9997's Avatar
Do you pack the area after the walks are up? Is this something that needs to be done every set up.. or is there a permanent fix?
Old 09-01-2015, 06:50 PM   #8
mudman2's Avatar
I do it each time I set up during bug season
2015 tundra
Old 09-01-2015, 07:20 PM   #9
Chuck, it only takes a minute to do both sides, so I haven't looked for a permanent solution. Yes I put it up after the a-frame is set up. Sometimes i remember to take it down before i take down the walls. Sometimes I just catch the pieces and toss them into the camper as I'm lowering the roof sections.
2015 A122S
Old 09-01-2015, 07:28 PM   #10
chuck9997's Avatar
Ok.. Sounds good. I'm getting the idea I just need to stuff something up in the apex between the roof and sidewall on each side.
Wonder why Rockwood doesn't fix this obvious defect?
light
