Old 06-20-2016, 05:16 PM   #21
Fred Tom and Bensinc,
Can someone help me with my questions on adding this external fridge fan?
I purchased a 12V fan from Grainger and a simple toggle switch so I can turn the fan on and off from inside the aframe.
My questions are regarding the wiring.
Attaching a PDF diagram I came up with and looking for input.
1. Red fan wire direct to post #1 on the switch
2. Hot wire/power source from 12V input direct to post #2 on switch.
3. Black wire from fan direct to 12V electrical round.
Do you agree with the above and my diagram?
Some confusion as to what wire is the 12V hot and what wire is 12V electrical ground. I have one white wire and one black and white wire going to the back of the fridge. (photo attached) I'm assuming the white wire is the ground? Can someone confirm?
Also, I'm not exactly sure how to complete the actual tap into these two wires. I see where there is a plastic piece (in the pic) where the wires connect to. This piece has six connection points (shown in pic). Would I just add the wiring to those same ports where the wires (white wire and black & white wire) from the 12V connect to as well?
Thanks - you guys seem pretty knowledgeable on this and hope one of you can assist. Sorry for my lack of knowledge but need and want to do this right.
Name:	12V Wiring.png
Big Red Camper
"If you always do what you always did, you'll always get what you always got."
2014 Rockwood A128S
2015 Chevrolet Colorado Z71 Crew Cab 4X4 Short Bed
Big Red Camper is offline   Reply With Quote
Old 06-21-2016, 07:37 AM   #22
IDK about the Grainger fan you purchased, but I highly recommend a 140 MM computer case fan for the quietness. If the Granger fan is similar, then it should be OK. The fan may not have any sound outside, but it will transmit vibration through the body of the camper that can be heard inside so quiet and a relatively slow fan RPM is a must. Plus the computer fan comes with a standard computer slip on connector and a pigtail it disconnects easily when removing the upper fridge compartment grille.
I used clamp on style taps from the auto parts store to tap the wires. In most cases of 12V, the colors are mismatched on RVs, because they use 120V colors (white for neutral or ground and black for hot or positive) rather than 12V standards. So I solder a length of white wire to the black lead and a black wire to the red lead so there is no visual confusion. The added wires are larger gauge to work with the taps and are more easily terminated to connect to the switch.
Per your diagram, you do want to switch the red (positive) lead on the fan and connect it to the black and white wire. But it never hurts to put a voltmeter on the wires to double check the polarity.
Electrical work is confusing if you are unaccustomed to it. So plan your job, as you have already done, take your time and double check (the voltmeter) and double think every step. I double check myself every time I work.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-21-2016, 10:13 AM   #23
Thanks for your response Tom. Guess I'll have to see about the fan I purchased. I purchased a Dayton DC Axial fan that says is made for computers, cabinet cooling, etc. It measures 4 11/16" which computes close to a 140mm fan. I also considered it because it is ball bearing construction and has a high CFM air movement at 170 CFM. I figured the more CFM moving cooler air over the coils the better. The high CFM might be related to a pretty high 3800 RPM at and to your point, maybe that will create too much noise??
Thanks for confirming the wires (hot and ground). Not sure what "clamp on style taps" are but will make a trip to the auto parts store and ask.
Where specifically did you tap into with your clamp on style taps for your hot and ground wires? If you have a pic (close up) of this and those clamp on style taps you speak of, that would be very helpful.
Thanks again!
Big Red Camper
2014 Rockwood A128S
Old 06-21-2016, 10:37 AM   #24
Tom - I actually found info on the clamp on style tap clamps you mentioned at this web site The Problem with Wire-Tap Connectors « Bareass Choppers Motorcycle Tech Pages so I know now what you are speaking about.
Still interested in seeing where you did complete your taps into the incoming 12V wires if you happen to have a pic.
Thanks again!
Big Red Camper
2014 Rockwood A128S
Old 06-21-2016, 11:24 AM   #25
Big Red Camper, What is the amperage rating on fan? I have one computer fan that is rated at almost 2 amps and another at .1 amp. Unless I missed it in your post I did not see the amperage rating. This is also an important factor in fan selection.
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 06-21-2016, 11:27 AM   #26
The fan I purchased at Grainger is 1.2amps.
Big Red Camper
2014 Rockwood A128S
Old 06-21-2016, 11:54 AM   #27
Yes, there is an issue with these connectors, particularly in high vibration applications. I used them because the camper is not high vibration, like a motorcycle would be, they are easily accessed and I know just where the connection is if there is an electrical failure. YMMV
Googling 140mm computer case fans gives me an estimate of 61 CFM at 1000 RPM and 0.08A draw. For about $9.00. That is more than enough flow to turn over the air in the entire compartment several times a minute. It should be sufficient to draw air over the fins.
Oh, yes, and you can get cool LED lights in the fan make it sparkle. If that's your thing.
ETA. One more thing, think about what will happen when you touch the moving fan blade. From personal expereince, I can say it just stops with no damage to it or me.
Tom
2012 Rockwood A122S
Old 06-21-2016, 12:00 PM   #28
I tapped it just where your photo is. On the wire coming from the converter out of the wall to the crimp on "wire nut" connector. That connector could be replaced too rather than use a crimp on tap. But to do it according to Hoyle, you likely need a special crimp tool. I have some electrical and electronic wiring crimpers but don't know which is right for this connector.
Tom
2012 Rockwood A122S
Old 06-22-2016, 06:41 AM   #29
I found the photo of my taps. It's blurry but here it is.
Tom
2012 Rockwood A122S
Old 06-22-2016, 08:41 AM   #30
I DO love our HW192 fridge! It takes awhile to cool, but works well once cold. I tested the little freezer compartment by putting a bottle of water in it before we went to bed on our last camping trip. The next morning, the water in the bottle was rock-solid ice.
Jodilc is offline   Reply With Quote
a-frame, frame, fridge
