Old 07-29-2016, 10:03 PM   #41
It happens that I did the 120mm size fan.
I installed it similar to the posted method, and only as a "just in case" mod.
It also happens that I tested it with the very high 90s temps recently, and even though I did not record scientific data, the results were very good and a significant improvement was made. It's worth it!
mickrock is offline   Reply With Quote
Old 07-29-2016, 10:14 PM   #42
Excellent Glad it worked out. It would be nice if these types of mods would be standard in our fridges, but I guess that would give us all nothing to do then . Enjoy.
2015 FR Classic 625D
2011 Toyota Sienna, AWD
Dodaman is offline   Reply With Quote
Old 08-08-2016, 08:24 PM   #43
Ok before I start I have hated refrigerators since I owned sailboats. They are grossly overpriced and generally poorly made junk.
Now I have that out of my system I have only one word for anyone who want a real refrigerator.
ENGEL.
Mine is the size of a good size ice chest and they come much larger. Mine has been running pretty much full time for ten years. It only has one moving part. The system is called a Sterling Engine. It will run on 12v or 110v and if you have it plugged into both if the 110v goes out it will automatically switch to 12v. It's not just a fridge but will freeze a gallon jug of water hard as a brick over night all the while only using 3.2amps.
When I had it on my boat with the doors closed the interior of the boat would be well over 90* and my beer would be about 32*. How much happier could I be.
I love my camper and my ENGEL makes it that much better.
2016 Rockwood A212HW
2000 Ford F-250 7.3lt 2WD
2000 Ford F250 7.3lt 2WD
cantxsailor is offline   Reply With Quote
Old 08-09-2016, 11:26 AM   #44
Hello Cantxsailor -
Glad you have found a product you like. Not sure I want to add another item to haul around with me on my camping trips so I'm glad some of the folks in this forum were able to help me get my fridge operating at a high level.
If you are experiencing similar cooling issues with the fridge that came with your aframe, read through this thread. You'll find that there is a pretty quick modification that can be made to your fridge to make it work well in extreme high temps. The fridge will get as cold as you want it to.....freezing if you desire! This is the single best modification I've made to date for my aframe.
One other advantage to this mod over obtaining a secondary cooling product like the ENGEL is that you'd also be able to take advantage of using the propane option on your camper fridge as well if you make this mod.
Best regards,
Terry
Big Red Camper
"If you always do what you always did, you'll always get what you always got."
2014 Rockwood A128S
2015 Chevrolet Colorado Z71 Crew Cab 4X4 Short Bed
Big Red Camper is offline   Reply With Quote
Old 08-09-2016, 04:13 PM   #45
cantxsailor,
I really don't agree that RV fridges are poorly made or junk. There are fridges and there are fridge installations. Folding campers installations are typically substandard due to the inability to vent the fridge upward. That is not the fault of the fridge.
It is also easily overcome with a small piece of reflectix for a baffle and one or two off the shelf computer fans. A single 140MM computer fan draws substantially less 12V power than a stirling engine (0.5 to 2.87 amps) and I would guess it is quieter. While the fridge found in low side campers doesn't draw any power when operating on propane.
It's good you've found something that works for you and these may be a alternative for those with good solar systems, but please don't overplay the drawbacks of less expensive standard RV fridges.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-11-2016, 11:22 AM   #46
Big Red and Pooneil
Thanks for the details on the fridge exhaust fan installation. We decided to use our A-frame in lieu of a hotel in returning my daughter to Baylor next week. With Waco temps, I figured I needed to install the fan to make sure the fridge would keep food safely.
I had some 120mm sleeve bearing fans from my computer building days, but found a 120mm Insignia ball bearing fan at Best Buy for $10. The Insignia draws 70ma with a rated flow of 40cfm at 1200 RPM. Current was half what my sleeve bearing fans drew.
I never would have thought of mounting using tie wraps to the grill without you guys, so thanks. The tie wraps work great. I found a 4 pin to 2 pin fan cable in my box of computer parts, and used that to run the fan at full 1200 RPM.
I put an automotive LED lighted switch in near the CO detector. This meant only one wire to the fridge compartment; I tapped the 12V negative at the fridge, installing a new wire nut with the 3rd wire. I put the fan on the miscellaneous 15A circuit, since I had a bus bar for power distribution on that circuit from when I installed the PD converter. A negative connection to the switch for the LED from the common bus bar completed the install.
Started the fridge last night on AC at 8PM. Ambient garage and fridge temp was 82. At 3AM (7 hrs later), the fridge was at 29, garage was at 74. Dialed back the fridge to 4 and left for work. I think this is a great mod. My only concern is that performance without the fan may be reduced by the stationary fan partially blocking air flow. I did move the fan as close to center as I could, while still having it over the open grill slots. And the fan only exhausts into the bottom 2 slots of the upper vent, the top slot is free and clear.
The blue LED on the switch is way too bright - brighter than the night light. I will be installing a resistor in the negative leg of the switch LED circuit. I will start with 1K and go up from there until I get the brightness reduced.
Again, thanks for leading the way.
Fred W
2014 Rockwood A122 A-frame
Old 08-11-2016, 06:26 PM   #47
Hey Fred,
Thanks for the recognition but I only followed the direction and advice from others on this mod. Credit goes to Tom and Bensinc who were very helpful in responding back with information and pics and also to you as well with the reflectix baffle information.
It does go to show that if I could complete the mod, anyone can!
Terry
Big Red Camper
2014 Rockwood A128S
Old 08-11-2016, 08:53 PM   #48
Home tonight at 6pm. Garage was stifling and 89. Fridge is holding 36 with knob at 4 all day. I think we'll do OK in Waco.
Now to dim the LED in the switch.
Fred W
2014 Rockwood A122 a-frame
Old 08-12-2016, 05:46 PM   #49
Completed the install of the fan. Temp was holding between 30 and 33 with the AC dial set on 4, fan on.
Have turned the fan off to see how it goes. Heat is coming out of top slot instead of bottom 2 slots of top grill, which is what I wanted with the fan off.
Put a 100K resistor in series with the LED to get brightness down to a tolerable level. 1K and 10K didn't do much. Resistor is in the 3rd wire negative connection, which powers the LED only. The 2 positive wires are input and output from the switch.
A great mod, thanks for the ideas and how-tos.
Fred W
Old 08-14-2016, 05:55 PM   #50
Question for all of you that already done the fan mod: Do you leave the fan on while towing? Or is there enough air flow from forward speed? Or since DC runs the full 160 watts continuously, is that enough cooling combined with the vehicle movement?
Leaving for Waco, TX tomorrow. Fridge is packed and already down to 39 degrees. Backed off AC cooling to #4 (fan on) to hold it in the 30s till departure in the morning.
Fred W
a-frame, frame, fridge
