Old 06-22-2015, 08:25 PM   #1
Interior Light Cover
What is the best way to remove these without scratching the ceiling? TIA!
ThePoms
Rockwood
2016 A212HW
thepoms is offline   Reply With Quote
Old 06-22-2015, 08:33 PM   #2
Ford Idaho's Avatar
Squeeze them in the middle pull it down.
Old 06-22-2015, 08:34 PM   #3
RSchleder's Avatar
Maybe a description or a picture of the light cover you have would get you some useful responses. I can't begun to help as I don't have a clue as to the configuration of your light cover--sorry!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 06-22-2015, 08:50 PM   #4
Ford Idaho that did the trick👏👏👏. Now I just have to return the bulbs we bought. Looks like replacing will have to be done by the dealer as the LED that are in there are soldered on😒. Thanks for the help!!
ThePoms
Rockwood
2016 A212HW
Old 06-22-2015, 09:00 PM   #5
ThePoms
Rockwood
2016 A212HW
You have the newer LED lights. Sorry I haven't seen them in person. The typical technique is to squeeze them until rounded end pops up so the tab is free. YMMV.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-22-2015, 09:04 PM   #6
Ford Idaho's Avatar
Ford Idaho that did the trick������. Now I just have to return the bulbs we bought. Looks like replacing will have to be done by the dealer as the LED that are in there are soldered on��. Thanks for the help!!
ThePoms
Rockwood
2016 A212HW
Forgive me for asking but why do you want to switch bulbs?
If the bulbs are indeed soldered in then a fixture replacement may be called for.
Old 06-23-2015, 11:54 AM   #7
This is very interesting to me, as I just had one of the interior LED lights fail to a dim light (like a flourescent that's failing to start). The other interior LED is still fine (and quite bright). I never would have expected an LED to go dim - just work or not work.
I was hoping to just replace the LED but it sounds like it's hard wired in. Haven't had a chance to set the A-frame up since it happened and check it out.
Fred W
2014 Rockwood A122
Old 06-23-2015, 01:25 PM   #8
Ford Idaho, I bought what I thought was the correct replacement bulb. I just wanted to have one in the tool kit for JIC.
ThePoms
Rockwood
2016 A212HW
Old 06-23-2015, 06:25 PM   #9
Ford Idaho's Avatar
ThePoms
Rockwood
2016 A212HW
Okay, I was just wondering what was up...
Old 06-24-2015, 06:13 AM   #10
MinneweeseMI's Avatar
500mw Interrogation Laser Replacement
I was thinking about posting this under its own thread a couple of weeks ago, but this seems like a good place for it.
I never liked how bright the LED lights are on the walls, when DW turns one on there's momentary blindness and I worry about leading aircraft off course, so I replaced them with something dimmer and warmer.
They are soldered in as mentioned above and this pic will show it is definitely in the prototype stage. Much easier on the eyes.
Mark and Dawn
Michigan
2014 a122s
2014 Tacoma Double Cab
Our YouTube Channel
Days Camped 2017: 106
MinneweeseMI is offline   Reply With Quote
cover, light
