Old 09-24-2013, 08:29 AM   #1
Is furnace function correct??
I have been camping up in Montana with some cooler mornings requiring a little heat, more than the heat pump can handle. When I run the propane furnace, the heat pump fans also, blowing what feels like cold air from outside. Is it normal for the heat pump fan to run when the propane furnace is running? None if my other rv's had a heat pump, so I am not sure if this is normal.
Thanks,
Tony
Tony w is offline   Reply With Quote
Old 09-24-2013, 08:42 AM   #2
Retread Popup Owner
Wojo's Avatar
Hi Tony. Your fan setting on your thermostat is likely set to "Low" or "High". Set it to "Auto", and you should see the Cool Cat fan staying off when the furnace is running.
2014 Flagstaff T12DDST A Frame
2015 Nissan Xterra
2015 Nissan Frontier
Camping Photos
Camper Mods
Wojo is offline   Reply With Quote
Old 09-24-2013, 09:51 AM   #3
The Cool Cat recirculates the inside air and in normal operation does not have any way to draw a significant amount of air in from the outside. However if the camper is cool inside the blowing air will feel even colder. There seems to be some differences in the thermostats from year to year, so if you can put the year and model of your camper and TV in your signature, it will help people to help you.
Use this link
http://www.forestriverforums.com/for...=editsignature
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 09-24-2013, 10:56 AM   #4
Retread Popup Owner
Wojo's Avatar
Good point, Pooneil. I made the assumption that because he was a new owner it was a new camper. Rookie mistake.
2015 Nissan Xterra
Camping Photos
Camper Mods
Old 09-24-2013, 08:55 PM   #5
At least it is helpful to those of us with short attention spans. Wojo, you mentioned setting the thermostat to "Auto." Other too have mentioned this setting but my thermostat has no auto setting. Is yours different from mine shown below?
A122s Thermostat by b2220128, on Flickr
Tom
2012 Rockwood A122S
Old 09-24-2013, 09:00 PM   #6
Retread Popup Owner
Wojo's Avatar
That's how mine looks. I set the mode to "Fan" then use the +/- buttons to switch between Low/High/Auto.
2015 Nissan Xterra
Camping Photos
Camper Mods
Old 09-24-2013, 09:09 PM   #7
I see, that is good to know. I just checked and mine has been on Auto, cycling on and off with the AC or heat pump function.
Tom
2012 Rockwood A122S
Old 09-25-2013, 01:05 PM   #8
Fixed!!
That was it. I do have a new 122s and will add that to my signature. I appreciate the help and am already more comfortable!!
Old 09-25-2013, 01:43 PM   #9
Tony, send a bit of that cool weather down south when you get some free time.
Tom
2012 Rockwood A122S
Old 09-25-2013, 02:26 PM   #10
Retread Popup Owner
Wojo's Avatar
Glad that did the trick for you.
2015 Nissan Xterra
Camping Photos
Camper Mods
furnace
