Old 07-19-2014, 07:06 AM   #1
Is it normal to see light at the corners of the roof?
We just got back from a great week of camping in the Black Hills, and while out I noticed that you can see a bit of light on each side of the top of the roof. Is that normal?
I can also see light around the door, and it looks like the top part of the door seal doesn't quite mesh with the frame. I'm not sure if that's normal either!
Thanks!
2014 Rockwood A122BH
2017 Nissan Pathfinder
bensinc is offline   Reply With Quote
Old 07-19-2014, 08:07 AM   #2
Mine also, haven't figured out if it is normal. But it doesn't leak.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (42)
dts3204 is offline   Reply With Quote
Old 07-19-2014, 08:54 AM   #3
OutAndAbout's Avatar
I have a small amount of light at the top 2 corners. Iíd say itís just the nature of the aframe. I have been in some very heavy rains with no leaks, not even when washing it except for maybe a few drops. My door though seals up pretty good.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 07-19-2014, 10:59 AM   #4
I see light at one of the peaks but not the other. A little bit of light where upper and lower door meet in corner at jamb but no water leaks.
mzak is online now   Reply With Quote
Old 07-19-2014, 05:54 PM   #5
FarFromStock's Avatar
We get the light in the corners too. Our solution: we shove a couple pieces of foam in each corner after we raise the walls. "Problem" solved.
...and...we're camping!!
Glenn & Debbie
2013 Rockwood A127TH (aka Carl)
2012 Ford Raptor
Camping born-on date: 21 July 2012
Nights camped: 2014-3 (so far!!); 2013-16; 2012-2 nights
FarFromStock is offline   Reply With Quote
Old 07-19-2014, 06:03 PM   #6
We also have "some light" in the corners. We found out the hard way in Alaska last summer. The mosquitos invaded and we had to hide under the sheets that night. Paper towels stuffed in the cracks solved the mosquito invasion. Never had water enter.
lonewolf465 is offline   Reply With Quote
Old 07-19-2014, 08:28 PM   #7
The small gaps on mine let the bugs in too. I've Learned not to leave the inside lights on at night when I'm out ot the camper. No water infiltration.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-19-2014, 09:08 PM   #8
I used adhesive backed foam and placed it where needed. Problem with bugs solved.
Shop Frost King 1.25-in x 10-ft Black Foam Door Weatherstrip at Lowes.com
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 07-20-2014, 04:26 PM   #9
Read the "First trip with NTU A122 - review" thread
for info about the upper door turntuckle.
mickrock is offline   Reply With Quote
light, roo, roof
