Old 05-10-2015, 10:01 PM   #1
Is Propane a better fuel than gas for a generator?
I would love to find out from those of you who have used generators in a small A122 trailer Whether installing a propane conversion kit on a 1000-watt or 2000-watt generator is a safer, better fuel choice than gasoline. We can haul a maximum 2700 pounds in our Subaru Outback, so the generator will likely be transported inside the trunk.
If you use gasoline, do you experience gas fumes in your tow vehicle or is the generator sealed well enough that there are no fumes?
How long does gas generally last in your 1000 or 2000 (more than 3.8 hours?)
What other considerations would you have for us regarding propane vs. gas in a small generator?
Thanks in advance for your wisdom.
Kanikamom is offline   Reply With Quote
Old 05-10-2015, 10:54 PM   #2
Left Coast
If you use gasoline, do you experience gas fumes in your tow vehicle (e.g.,) or is the generator sealed well enough that there are no fumes? Also, on the fume thing..the Honda gas caps have a vent made into cap that you open to run, close to travel.
Gas...it's easier to find. No fumes if you carry in bed of pu....my Honda 2000 will run about 4 hrs., but depends on whats being powered up. If I need the ac, I hook up my other 2000 and have made my own extended stay fuel tank....this set-up will go more than 3 days, all day. Wife doesn't need to mess with 'em when I'm not there to re-fuel.
Old 05-11-2015, 02:54 AM   #3
Moderators' Assistant
bikendan's Avatar
Hondas have a vent cap that prevents fumes from escaping.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-11-2015, 07:30 AM   #4
I've seen where people have adapted or modded plastic totes to carry Honda generators to help reduce fumes within an SUV that come from the occasional spills. The totes also make storage easier because other items can be easily stacked on top. Also consider that if you try using the generator on gas and don't like the smell in you SUV, then you can add the propane conversion later.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-11-2015, 10:11 AM   #5
Thx Pooneil, I like your thought of trying it with gas and seeing if smell is a problem before buying the conversion kit. We could do that test before our camping trip.
Old 05-11-2015, 10:14 AM   #6
Is it easier to find gasoline on the road than propane, to refill a genny? I don't know how easy it is to get propane at/near the various types of camping facilities.
Old 05-11-2015, 10:54 AM   #7
bikendan's Avatar
No comparison.
Gas is way easier to find.
I don't know of any West Coast state parks that have propane for sale.
Some private RV parks have it available.
Old 05-11-2015, 10:59 AM   #8
Thx. That was my suspicion (easier to get gasoline), but I was not sure.
Old 05-11-2015, 11:22 AM   #9
mzbrandi's Avatar
I haul 2 Hondas in the back of my Jeep 4 door with no smell of gas. You can turn the vents closed on the gas caps. As you can guess, you need to open the vents before using the gennerators. Don't ask me why this was important? :-)))
Brandi
mzbrandi is offline   Reply With Quote
Old 05-11-2015, 11:25 AM   #10
Left Coast
Was it because they needed the air to run longer than a minute or two?
gas, generator, propane
