Old 11-24-2012, 10:41 AM   #1
It's Collllllld! Crack the roof vent while running furnace overnight?
For those who are camping this winter and running the furnace overnight, have you been cracking your roof vent? Is it dangerous to not crack the vent or is it just for condensation reasons?
We have camped 8-10 nights in the cold this Fall. I have been setting the thermostat to 60 degrees and cracking the roof vent for "safety reasons." However, the last night of our recent Thanksgiving camp, I had too many sodas and forgot to crack the roof vent. Thankfully, we all survived.
There seemed to be the same amount of condensation on the windows in the morning...but it seems as if the furnace didn't cycle as much as when the vent is cracked. Granted, the sodas might have something to do with how many times I noticed the furnace kicking on that night but it would make sense that it would work less with the roof vent being closed. Any thoughts/experiences are greatly appreciated.
LM
2012 Flagstaff T-12DD
2004 Chevy Suburban
2000 GMC Sierra Z-71
loganmartin is offline   Reply With Quote
Old 11-24-2012, 10:57 AM   #2
MtnGuy's Avatar
The onboard furnace is a "closed" system, just like the furnace at a house. There should be no need to open a window or vent if the system is functioning properly. If there were to happen to be leak in the burner mechanism or the flue to the outside, that could pose a problem. Make sure you have a properly functioning CO dectector.
Cracking a window or vent would probably cut down on some condensation in the camper.
A heating system like the Buddy Heater where there is not a fresh air intake and exhaust to the outside does require a window or 2 to be cracked.
Old 11-24-2012, 11:03 AM   #3
Gotcha...that is what my intuition was telling me but I wanted to check in with the vets to be safe. I honestly didn't see any difference in the condensation so I will be a closed vent guy from now on to save a little propane. I am very impressed with the furnace in our little a-frames.
Thanks!
LM
2004 Chevy Suburban
Old 11-24-2012, 11:06 AM   #4
MtnGuy's Avatar
I didn't realize that you had an A-frame....my bad. I presume that the furnace in those are similar to other trailers, but let's see what some other A-frame owners have to say before taking my word for it.
Old 11-24-2012, 11:35 AM   #5
acadianbob's Avatar
I would think that any manufacturer installed furnace would need to be vented to be legal.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 11-24-2012, 11:36 AM   #6
I am not as experienced as other A Framer owners. But, my recollection is that they suggested we leave the vent open a crack since the A Frame is well sealed -- maybe too well sealed when there is a danger of CO2 from breathing in the night.
Tinsu is offline   Reply With Quote
Old 11-24-2012, 11:44 AM   #7
I believe it is a big boy furnace because it is vented to the outside.
2004 Chevy Suburban
Old 11-24-2012, 11:49 AM   #8
I have some daylight at the peaks of my a-frame and some other spots so I am thinking that it is less sealed than a TT or fiver. It sounds like alot of a-frame owners have slivers of daylight here or there. Maybe you got a good one.
LM
2004 Chevy Suburban
Old 11-24-2012, 12:23 PM   #9
handbuilder's Avatar
I dont leave a window cracked for the purpose of running the furnace...my CO detector should alert me to oxygen issues...my unit so far has been really snug, dry and warm. Weve been in some pretty hard cold rain with no problem. The only time I noticed daylight cracks was the time my unit was not completely level side to side..because its not one.solid.piece the tendency for the bidy to torque is greatly increased.
My first hint that its not level side to side is watching hiw well the dutch door catches together. The first few time I used the trailer, I bent the snot out of the right corner seams door halves come together and slightly overlap. Anothr sign the it is not level side to side is when the roof latch is harder to secure on one corner than the others..and this is the only times I have noticed daylight crack. DH says I should not bully the latch up...the trailer design will never be stable like a one piece traditional travel trailer & advises/reminds me to level all the way around....dont know if this will help others, but it has worked for me.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 11-24-2012, 12:54 PM   #10
Yeah, I fell better about running the furnace without the roof vent cracked. I will vent if I use a buddy heater or something in the future.
My daylight stemmed more from imperfections in the gasket installation from the factory than leveling issues. I have supplemented with my own gaskets and am satisfied with the overall fit now.
LM
2004 Chevy Suburban
