Old 12-27-2015, 12:02 PM   #11
I use a 8" by 10" piece of 1/2" plywood. Cheap, doesn't push into the ground.
lonewolf465 is offline   Reply With Quote
Old 12-27-2015, 12:19 PM   #12
A32Deuce's Avatar
Yes I remove it while traveling. Is great for setting up WD hitch. A lot less cranking!
2012 SunSeeker 3100SS Toad-1962 Futura
A32Deuce is offline   Reply With Quote
Old 12-27-2015, 12:33 PM   #13
jack block
While I use all yellow plastic blocks for the corner jacks, I must be old school when it comes to the front jack.
I have used an old creosoted block of wood, that is 10x10 by 14 inches. I know that sounds heavy, but it is surprisingly light. I toss it in the truck bed, when we pull off. It never soaks up water or begun to deteriorate, and I have had is sitting in snow and mud for almost 15 years.
On a particularly slanted area, I can put yellow blocks on top of the big block, and keep stacking.
BTW, why would anyone care how far to extend the jack, when you can stack up to it? If nothing else, get some more yellow blocks.
hankpac is offline   Reply With Quote
Old 12-27-2015, 12:52 PM   #14
I use what came on the trailer, and an 8x8x12, or 4x6x12. Only one of my current trailers has a foor, and thats my tt.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 12-28-2015, 03:27 PM   #15
chuck9997's Avatar
Thinking about ordering one of those FLIP JACKS.. does anyone know what size I need for a 2014 Rockwood a122s?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 12-28-2015, 07:37 PM   #16
moondog2000's Avatar
Originally Posted by youroo View Post
I constructed a Wood support that can be rotated (3) ways to give different Height levels as Not all Campsites are Level! It is light weight and Very strong with Composite contact areas! Youroo!! Pic. when I take one!
Now that's smart thinking,three heights out of one block.Gotta make one for myself.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 9
moondog2000 is offline   Reply With Quote
Old 12-28-2015, 08:18 PM   #17
indybp57's Avatar
I have the cone style and have never had an issue. Very stable and the height eliminates a lot of cranking. My TT is around 4000#.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 01-02-2016, 06:53 PM   #18
handbuilder's Avatar
I use the wheel on a Lynx pad
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 01-02-2016, 07:04 PM   #19
john5646's Avatar
I've made these, wanted something light, easy to carry several, so size can be what ever you want. Test pieces were made of osb, switched to plywood. 2" foam between 1/2" plywood, 3" sleeve of plastic schedule 40 in center and glued together. Click image for larger version
Name:	ImageUploadedByForest River Forums1451782995.836485.jpg
ID:	97168Click image for larger version
Name:	ImageUploadedByForest River Forums1451783013.211405.jpg
ID:	97169Click image for larger version
Name:	ImageUploadedByForest River Forums1451783036.945040.jpg
john5646 is online now   Reply With Quote
Old 01-02-2016, 07:41 PM   #20
I mentioned I used a piece of 1/2" plywood. I forgot to mention I installed one of these:
The Ultimate Jack | A-Frame Trailer Jack at its FInest!
It allows me to let the jack down and open the tail gate of the pickup without it banging into the top of the jack. Also, when setting up camp, it takes only a few turns of the jack to get the trailer off the hitch.
lock
