12-27-2015, 09:56 AM
Jack stand, Blocks, what?
Seems I'm always looking for some dodad or twiddlygig for my AFRAME (2014 Rockwood a122s). Especially in the wintertime. Anyway.. my camper has one of those little foot plates on the jack. Like this:
I would like to have a jack stand like this:
What do you use under your jack? and why?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
12-27-2015, 10:12 AM
Personally I have five different types of trailers but I wound prefer the top one its more stable and stays put, the lower one I would loose somewhere along the line, Or I would bump the tongue & it would fall off the cone........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
12-27-2015, 10:29 AM
On a previous camper.. 22 foot travel trailer.. i used the cone type stand. It was pretty stable.. The jack actually rests down in the top of the cone.. maybe an inch or so. With the weight of the tongue on the stand.. I don't think it would ever tip over. I have read that some people had them crack .. when trying to support a BIG camper. I don't think I would use it for an RV weighing much more than 5000 pounds or so.
My main objective is to reduce the amount of length needed to extend the jack.. these cones are about 8.5 inches tall.
12-27-2015, 10:53 AM
I constructed a Wood support that can be rotated (3) ways to give different Height levels as Not all Campsites are Level! It is light weight and Very strong with Composite contact areas! Youroo!! Pic. when I take one!
12-27-2015, 11:26 AM
I cut a 2 x 12 treated into 4 or 5 11 1/2" lengths and screwed together with 3" drywall screws to make a big block
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
12-27-2015, 12:02 PM
I would prefer this flip jack over the plastic cone.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
12-27-2015, 12:04 PM
I use one like the top one only it is 9 inches tall.
12-27-2015, 12:13 PM
A32deuce ...Using one like the top one, but 9 inches tall? Do you remove it while traveling?
And caper... does this flip jack stay attached while towing?
12-27-2015, 12:33 PM
Not sure where you're located I used to have a travel trailer and have a flip Jack that I would like to sell please let me know if you are interested
12-27-2015, 12:38 PM
I am in clinton, tn.. will your flip jack work on a 2014 rockwood a122s? I think the jack shaft is the same as the rockwood popup.
12-27-2015, 01:02 PM
I use a 8" by 10" piece of 1/2" plywood. Cheap, doesn't push into the ground.
12-27-2015, 01:19 PM
Yes I remove it while traveling. Is great for setting up WD hitch. A lot less cranking!
12-27-2015, 01:33 PM
jack block
While I use all yellow plastic blocks for the corner jacks, I must be old school when it comes to the front jack.
I have used an old creosoted block of wood, that is 10x10 by 14 inches. I know that sounds heavy, but it is surprisingly light. I toss it in the truck bed, when we pull off. It never soaks up water or begun to deteriorate, and I have had is sitting in snow and mud for almost 15 years.
On a particularly slanted area, I can put yellow blocks on top of the big block, and keep stacking.
BTW, why would anyone care how far to extend the jack, when you can stack up to it? If nothing else, get some more yellow blocks.
12-27-2015, 01:52 PM
I use what came on the trailer, and an 8x8x12, or 4x6x12. Only one of my current trailers has a foor, and thats my tt.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
12-28-2015, 04:27 PM
Thinking about ordering one of those FLIP JACKS.. does anyone know what size I need for a 2014 Rockwood a122s?
12-28-2015, 08:37 PM
Now that's smart thinking,three heights out of one block.Gotta make one for myself.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 27
12-28-2015, 09:18 PM
I have the cone style and have never had an issue. Very stable and the height eliminates a lot of cranking. My TT is around 4000#.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
01-02-2016, 07:53 PM
I use the wheel on a Lynx pad
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
01-02-2016, 08:04 PM
01-02-2016, 08:41 PM
I mentioned I used a piece of 1/2" plywood. I forgot to mention I installed one of these:
The Ultimate Jack | A-Frame Trailer Jack at its FInest!
It allows me to let the jack down and open the tail gate of the pickup without it banging into the top of the jack. Also, when setting up camp, it takes only a few turns of the jack to get the trailer off the hitch.
