Old 12-27-2015, 08:56 AM   #1
chuck9997's Avatar
Jack stand, Blocks, what?
Seems I'm always looking for some dodad or twiddlygig for my AFRAME (2014 Rockwood a122s). Especially in the wintertime. Anyway.. my camper has one of those little foot plates on the jack. Like this:
I would like to have a jack stand like this:
What do you use under your jack? and why?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 12-27-2015, 09:12 AM   #2
Oaklevel's Avatar
Personally I have five different types of trailers but I wound prefer the top one its more stable and stays put, the lower one I would loose somewhere along the line, Or I would bump the tongue & it would fall off the cone........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-27-2015, 09:29 AM   #3
chuck9997's Avatar
On a previous camper.. 22 foot travel trailer.. i used the cone type stand. It was pretty stable.. The jack actually rests down in the top of the cone.. maybe an inch or so. With the weight of the tongue on the stand.. I don't think it would ever tip over. I have read that some people had them crack .. when trying to support a BIG camper. I don't think I would use it for an RV weighing much more than 5000 pounds or so.
My main objective is to reduce the amount of length needed to extend the jack.. these cones are about 8.5 inches tall.
Old 12-27-2015, 09:53 AM   #4
I constructed a Wood support that can be rotated (3) ways to give different Height levels as Not all Campsites are Level! It is light weight and Very strong with Composite contact areas! Youroo!! Pic. when I take one!
Old 12-27-2015, 10:26 AM   #5
jeff64's Avatar
I cut a 2 x 12 treated into 4 or 5 11 1/2" lengths and screwed together with 3" drywall screws to make a big block
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 12-27-2015, 11:02 AM   #6
caper's Avatar
I would prefer this flip jack over the plastic cone.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-27-2015, 11:04 AM   #7
A32Deuce's Avatar
I use one like the top one only it is 9 inches tall.
2012 SunSeeker 3100SS Toad-1962 Futura
A32Deuce is online now   Reply With Quote
Old 12-27-2015, 11:13 AM   #8
chuck9997's Avatar
A32deuce ...Using one like the top one, but 9 inches tall? Do you remove it while traveling?
And caper... does this flip jack stay attached while towing?
Old 12-27-2015, 11:33 AM   #9
MrNiceGuy's Avatar
Not sure where you're located I used to have a travel trailer and have a flip Jack that I would like to sell please let me know if you are interested
MrNiceGuy is offline   Reply With Quote
Old 12-27-2015, 11:38 AM   #10
chuck9997's Avatar
I am in clinton, tn.. will your flip jack work on a 2014 rockwood a122s? I think the jack shaft is the same as the rockwood popup.
lock
