Old 07-10-2014, 07:28 PM   #1
Just weighed my trailer
I just got back from the coop where I weighed my loaded up 122BH, and thought you might want to see what it weighs!
The trailer is 2300, and the tongue weight is 340.
That's with all of the items I'll keep in the camper, except for food. I'm not planning to drive with water on board.
The tongue weight is close to my max of 350, but I had some cargo on the deck. I should be able to move it around a bit!
I also have the power tongue jack, which adds some weight. I don't really like it (I could crank faster big hand), so I might get rid of it.
2014 Rockwood A122BH
2017 Nissan Pathfinder
bensinc is offline   Reply With Quote
Old 07-10-2014, 09:19 PM   #2
Makin' Life Simple
skisteveski's Avatar
Did mine also, (A122BH) and it came in at 2800 with water, two bikes, full propane & gear except food.
skisteveski is offline   Reply With Quote
Old 07-10-2014, 09:59 PM   #3
I actually only have one propane tank filled to save some weight!
I moved 23lbs worth of camping chairs and probably around 15lbs of my BAL leveler to the compartment under the bed, so I should be around 300lbs on the tongue now.
Old 07-10-2014, 10:04 PM   #4
TURBS's Avatar
Im slightly confused...
You have a max hitch weight of 350 lbs?
Old 07-10-2014, 10:17 PM   #5
Correct!
trailer
