Old 06-02-2014, 06:59 PM   #1
dobieaframe's Avatar
Latching down when traveling.
I was wonder how tight everybody latches down their roof when in the collapsed position? Is there such a thing as too tight or too loose?
dobieaframe is offline   Reply With Quote
Old 06-02-2014, 07:15 PM   #2
Old 06-02-2014, 08:01 PM   #3
Just snug enough that it pulls down a bit. But certainly not tight.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-03-2014, 07:54 PM   #4
latches are adjustable and top seats on foam rubber gasket/ I have mine tight enough to make them snap when I lock them/if they are to loose top may not seal they are adjustable and should be at least medium tight/what do others think o subject????
2014 A122s rockwood 2014 jeep grand Cherokee v6 290 hp 4by4
ridgeline1 is offline   Reply With Quote
Old 08-03-2014, 04:55 PM   #5
Bob P's Avatar
Roof latches
Just picked up our Flagstaff 2015 T12TST this past July 30, 2014. The dealer spoke very strongly "do not overly snug the hold downs for the roof". He said he just had a repair in, where the hold downs were really overly tightened. The owner went over a rough rail crossing and one of the hold downs pulled out the entire fiberglass area of that mounting on the side of the trailer. Something like 700 dollars in repairs. Impressed me..
2015 Flagstaff T12TST A Frame
2011 Toy. Sienna w/tow prep
Bob P is offline   Reply With Quote
Old 08-07-2014, 08:17 AM   #6
Please tell me if anyone has had a problem with any of the latches on the aframe. We just purchased our little camper in May and when taking down in the rain in July we had trouble getting one of the latches to release. Since then it has gone from bad to worse. Now we cannot even get the same latch in the slot to set up the camper. Any suggestions, We are not looking forward to pulling the camper all the way back to the dealer....Thanks much..
Nellsaframe is offline   Reply With Quote
Old 08-07-2014, 09:47 AM   #7
Welcome to the forum.
In case you haven't tried this...
The latches are adjustable. The lower latch piece with the hook is on a screw and can be unscrewed to lengthen the reach until it will slot into the upper hook. Adjust so it closes firmly but doesn't pull down too tightly.
Tom
2012 Rockwood A122S
Old 08-07-2014, 04:24 PM   #8
I did not make myself clear,,but thank you for your quick response..Our problem is with the latch on one of the walls...it is not on the wall that the door is one, but the other wall...we ended up taking the camper into the dealer/service department..We just could not get the wall latch to go into the slot..Thank you so much,,,I should have written more in my questions..We do love our aframe, but just want to be able to get the wall up..hehehe
Old 08-07-2014, 08:46 PM   #9
E325's Avatar
2014 Rockwood A122s
2010 Toyota Tundra
Days camped in 2014------14
E325 is offline   Reply With Quote
Old 08-07-2014, 08:52 PM   #10
I had that problem once,
and fixed it by tightening up the nut on the handle.
If it gets just a little loose, there is too much play.
mickrock is offline   Reply With Quote
travel
