Leak outside on a212hw - anyone have this issue?
Just got my 2018 A212Hw. Had it for 2 wks so far and noticed moisture outside on bottom of left wheelwell on side of sink & ac (1st noticed watermark on ground where it evaporated). Called dealer & they said its probably from condensation from a/c but i only tested a/c during walkthru and & I wouldn't think there would still be moisture there since it would have evaporated over 2 wks.
I opened back panel of cabinet next to microwave where hoses are. There was water on bottom near microwave under sink. Couldnt find any wet hoses anywhere for possible leak so I filled tank, dried all moisture, and charged the faucet up to let water run. No apparent leaks.
When I removed faucet stem to break camper down, water flooded out a bit after I relieved all pressure so I stopped that up, put a rag down as far as I could go to help stop excess from coming out again after camper was secured.
This morning, everything's wet again on outside. Could this be the issue?? Water still coming out and leaking between faucet stem and faucet where it's not sealed? I'd hate to keep unscrewing the back & ultimately ruining the wood but really don't care to have mildew or flooring trim in back of cabinet warp, either.
The tech said to bring it in in a cple weeks if this. Is it normal for water to shoot out after removing stem when there is no apparent pressure??
Any help is greatly appreciated.
