Old 01-20-2016, 05:11 PM   #1
Leak when traveling
I have a Rockwood A122S. After traveling thru a rain storm in Florida this Jan
2016. Found water all over inside the camper. From benches, stove, window curtain, floor and even the front storage area. Could not tell where it came in. Roof vent was closed and locked! Need help to figure out. Long way home to upstate NY.
Banjo64 is offline   Reply With Quote
Old 01-20-2016, 06:04 PM   #2
1A Camper's Avatar
I need to tighten up the side roof latches ( one on each side ) as the front roof was not pressing into the black foam that runs across the aft roof. That solved my problem.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 01-21-2016, 02:02 PM   #3
DanM-AZ's Avatar
My first suspicion would be the bubble windows. How old is the trailer? Set it up and hose the two slopes, then check for leakage inside. If you find the bubble windows leaking, it's time for the 3M Extreme Sealing Tape treatment.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 01-21-2016, 03:59 PM   #4
It is a 2016. Bubble windows seem fine still. Was not Sure if roof vent because when driving it is really backwards.
Old 01-22-2016, 07:32 AM   #5
MinneweeseMI's Avatar
Leak from storage compartment
This is probably not the ultimate source of all the water, but we notice that if we tow in the rain, it seems to shoot up from the TV rear tires and sneaks in under the front storage lid. We are working out some solutions but nothing that great so far.
The front storage latches are as tight as they can be without cutting the threaded adjusters. We may do that next season, it would probably only take 1/4" to make it much tighter.
Just a thought.
Mark and Dawn
Michigan
2014 a122s
2014 Tacoma Double Cab
Our YouTube Channel
Days Camped 2017: 106
MinneweeseMI is offline   Reply With Quote
Old 01-22-2016, 10:24 AM   #6
I would suggest to recheck your fantastic fan for any residual moisture....as its a 16 its time to take it to the dealer so they have a look see and you get a papertrail on the issue.
D-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 01-23-2016, 11:59 PM   #7
Oh heck no! When you figure it out please let us know
Auntielo1 is offline   Reply With Quote
Old 01-24-2016, 09:39 AM   #8
Took it in to tamparv. They replaced the foam seal on the back roof panel and added an additional rubber seal on the top roof panel. They feel it will get us back to Albany NY, our home, dry. But rear roof panel is bent and need replacing.
Old 01-24-2016, 09:41 AM   #9
They did a great job to fit us in. Thanks to Liz, Louis, Kerry. Thanks for fitting us in.
leak, travel
