Old 06-12-2018, 11:35 PM   #11
JArry's Avatar
I installed 2-inch Eternabond around my rear skylight about a year ago. No leaks so far. I will probably end up doing the fronts eventually as well.
2016 Flagstaff T12RBST A-Frame (same as Rockwood A122S) | 2006 Honda Ridgeline RTL
Nights camped in 2016: 37; 2017: 52; 2018: 47
JArry is offline   Reply With Quote
Old 06-13-2018, 05:56 PM   #12
Well I just found a few leaks on my front skylights as well. When I bought my A122s last September the dealer decided to hide a broken corner on it with a huge gob of silicone, see photo. After peeling off the silcone blob I found the damage, see photo. If the dealer had told me about it then I would have had them install a new one. Needless to say I'm ticked off. Have ordered a new one and will install it in a few weeks. Get aload of the bead job they did. A blind man could have done a straighter bead than that crooked piece of crap.
ID:	175793   Click image for larger version
ID:	175794   Click image for larger version
ID:	175795   Click image for larger version
ID:	175796   Click image for larger version
Oksourdough is offline   Reply With Quote
Old 06-13-2018, 07:49 PM   #13
Send these pictures to Forest River Warranty Rep. and tell her your story, she just might get it replaced at no cost to you. Won't hurt to try.
2017 Rockwood A213HW
2017 Chevy Colorado Z71 4x4 V6
backpacker3 is offline   Reply With Quote
Old 06-13-2018, 07:54 PM   #14
Unfortunately it was a used 2014 model so not likely to get any help from Rockwood. The dealer is at least looking at helping out. I just have to wait and see what they do.
Old 06-13-2018, 08:27 PM   #15
Sorry, thought it was a new purchase. Too bad the dealer had to do that to a customer, I hope they try to make it right. Good Luck.
Old 06-14-2018, 02:32 PM   #16
MontyPP's Avatar
It may have been the previous owner's attempt to patch it.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is offline   Reply With Quote
Old 06-14-2018, 04:42 PM   #17
Nope. It was the dealer as I have the photos from their website of the unit prior to buyi g it. No blobs.
Old 06-14-2018, 05:22 PM   #18
Well a big thank you to Voyager RV in kelowna who are sending me a cheque to cover the cost of purchasing a new skylight. Thanks guys.
Old 06-14-2018, 05:48 PM   #19
MontyPP's Avatar
Nice of them.
Flagstaff T21TBHW
Old 06-16-2018, 07:32 AM   #20
I had a similarly bad experience with a Toppers and a cracked window. The replacement was done with about as much care as that bead and they also used silicone, which is a poor choice of materials for the purpose.
After it started leaking and I could get it back to them some time later, to my surprise, they took responsibility for the bad work and remove and reinstalled the window at no charge. This time using Decor sealant.
Many RV dealers, even of they have customer friendly management in a pinch, still cut corners when they can and haven't yet learned the lessons of total quality.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
leak, window
